05-20-2011, 08:34 PM | #2276 |
yes, i do
Re: What did you do to your truck today!
removed the drivers rocker since the only welds holding it in were what i put in it. 3 tack welds and a couple cuts later i now have room for the new rocker. i just gotta put it in now
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
05-20-2011, 08:54 PM | #2277 |
Bled the new power steering unit. Working flawlessly. I am so stoked that it actually works as good as it does. What a difference it makes in the drive.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
05-20-2011, 10:18 PM | #2278 |
I cut some holes in my trailing arm cross member for my exhaust and welded in some 4" pipe to sturdy it up and keep it clean.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
05-21-2011, 12:43 AM | #2279 |
yes, i do
got my replacement cab support and driver's rocker tacked in place. i'm actually rather impressed with how well this novice body man did!
05-21-2011, 08:56 AM | #2280 |
PROJECT 7DEUCE
Started to weld up the cab seams.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-21-2011, 09:19 AM | #2281 |
22nd attempt at getting my signal/brake light issue fixed and changed oil
05-21-2011, 10:34 AM | #2282 |
Put in a corvette servo in my 700R4 and took for a drive. 1-2 shift is much better now, not hard by any means but at least I don't have to let up on the pedal when it shifts.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
05-21-2011, 11:11 AM | #2283 |
I sold my original 283 this morning on craigslist $100 ! good bye, time to clean up that frame, .
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
05-21-2011, 02:11 PM | #2284 |
Changed the oil. I know that is boring but it had to be done.
Big Block Powered |
05-21-2011, 03:09 PM | #2285 |
Installed new sending unit from LMC, painted oil dipstick.
05-21-2011, 09:33 PM | #2286 |
Replaced the ignition cylinder,the dash pad , got it registered, took apart a / the carb for the first time and cleaned out the fuel bowl Now it runs a lot better.
Posted via Mobile Device |
05-21-2011, 10:35 PM | #2287 |
Opened the hood, hooked up the horn, Honked it to try to get the dog to come home.
05-21-2011, 10:55 PM | #2288 |
I installed a tach kit today. My truck didn't come with a tach originally. Also took it to a show after I cleaned it up.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
05-22-2011, 12:25 AM | #2289 |
looked at it walked passed it quite a few times while working on my bug, sat a few things on it for a little while while i was working on the bug then took the stuff off when i was finished
05-22-2011, 01:33 PM | #2290 |
Painted the wheels and ordered the baby moons
05-22-2011, 01:52 PM | #2291 |
cleaned the bed up. need to repair some of it where someone ran exhaust stacks on it sometime in the past.
before after |
05-22-2011, 05:42 PM | #2292 |
Finished the clean up on my frame. Off to powder coat
05-23-2011, 02:29 AM | #2293 |
Not today but yesterday I gave a wash and photo shoot for my truck: http://67-72chevytrucks.com/vboard/s...d.php?t=465927
05-23-2011, 06:51 AM | #2294 |
Well I finished putting my rear brakes back together and filled my diff with fluid. What a pita it was getting the fill plug out, somebody put a cast plug in for the original, it wouldn't budge so it broke into several different pieces. Had to heat it with a torch to get it out. Then I finished the routing the pipes on my side exhaust where they exit in front of the tires and grinded down all the welds.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-23-2011, 08:45 PM | #2295 |
Junior Member
working on the 59 dash install
05-23-2011, 09:44 PM | #2296 |
Old Skool Club
Crazy thing about those '59 dashes...as wide as they were, don't you have to narrow it to put it in our trucks? There's a guy near here who put a dash from a '59 Edsel in his '68. He had to widen it to make it fit.
I said that because I remember how wide they seemed to be when they were new. Dad bought a '59 Ford, while my cousin bought a '59 Impala HT. When I started driving, it was on the Ford. Back in the day, there was some scuttle about having to add marker lights on the fins of the Chevy. Seems it was just under the width limit. Oh, I like it. But, on my truck...son and I reattached the engine cross member and the trailing arms. Waiting on the upper/lower control arms so we can get some ball joints and start that phase. But, we worked on it for a change.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
05-23-2011, 10:47 PM | #2297 |
Junior Member
Belive it or not I had to add about 5" to the dash but that could of been from the way it was cut out of the donor car. It was a ebay deal, Next time I will ask for more pic. for sure. I leaarned to drive a stick in an old impala in the driveway .So It will be cool to look at that dash again ! But I have a long way to go to be driving this one
05-25-2011, 12:50 AM | #2298 |
70Custom10
I put my stepside box on!
05-25-2011, 11:30 AM | #2299 |
Ordered some parts last night, to get my motor really tuned in. Right now its just a little rich lol. Ordered a jet and rod kit for my Edelbrock 650 Thunder series carb, a timing tape, and some distributer advance weights and springs for the MSD HEI on my motor, oh and a vaccum gauge. Hope to lean out the idle so your eyes dont water when you stand beside it, and get some better gas mileage and get rid of the bog down when I put my foot to the floor. Gonna be a high octane weekend with some high speed blasts down a back road doing test and tune
05-25-2011, 03:08 PM | #2300 | ||
"I ain't nobody, dork."
Actually it was yesterday. Installed new set of MSD Ignition 8.5mm Super Conductor plug wires. Way better than the cheapo Accel Super Stockers I had in there before.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
