05-08-2016, 05:50 PM | #2276 |
Re: What did you do to your truck today part III
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
05-09-2016, 10:51 AM | #2277 |
Mounted the bumper Saturday and License Plate Bracket. Only thing left if the door glass, Hopefully this week some time.?
http://s1299.photobucket.com/user/jb...23904108567829 |
05-10-2016, 08:41 PM | #2278 |
I installed a new Weber 32/36 and she runs! Woo-hoo! She idles smooth and there is no black smoke from running ridiculously rich! Goodbye Rochester B!
05-10-2016, 09:03 PM | #2279 |
Post Whore
Now where are the pictures?!??! Or the video!?!?!?!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-10-2016, 09:11 PM | #2280 |
I sent you a PM. Needing a little advice about my Weber.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
05-11-2016, 12:18 AM | #2281 |
05-11-2016, 09:47 AM | #2282 |
It's Better With Nitro
Started to make my cuts to the bed wood and strips for the access panels to the rear end housing and gas tank fillers. Next will be making the cuts for the widened wheel tubs.
05-11-2016, 12:37 PM | #2283 |
Passenger door worked,epoxied and urethaned. Ready for blocking. On to the other side.
05-11-2016, 10:28 PM | #2284 |
Post Whore
Scored a set of bumper guards for my GMC. Also chrome painted the valve covers cause I had the paint laying around. lol Looks pretty good to me!
05-12-2016, 12:20 AM | #2285 |
Painted my drivers door jam faw
05-12-2016, 07:32 PM | #2286 |
Got IDIDIT chrome plated column in.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-12-2016, 08:49 PM | #2287 |
Looks good! Mine is on the way from Summit as we speak. Excited to get it. Seem like a quality unit?
05-12-2016, 08:54 PM | #2288 |
Slid into place like a factory fit. Looks like 73 up internals. Of all aftermarket parts I have this is by far the best quality part without a doubt.
05-12-2016, 10:41 PM | #2289 |
Did you order a universal or the one that calls for your truck? Do you have part #s?
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
05-14-2016, 08:05 PM | #2290 |
Door no 2 epoxied and urethaned.. Hopefully next sat they turn green.
05-14-2016, 11:01 PM | #2291 |
Post Whore
05-15-2016, 07:21 AM | #2292 |
05-15-2016, 09:20 AM | #2293 |
Dayum!
05-15-2016, 10:24 AM | #2294 |
I opened the engine to see what was not letting it turn
found that 1,7, and number 2 cylinders had white powder in them causing them not let pistons to come up to top of stroke, removed intake, removed heads, , after cleaning them, the motor turns with no problems now will go and get new gaskets and put her back together, and see if she will run |
05-15-2016, 10:26 AM | #2295 |
Post Whore
05-15-2016, 10:30 AM | #2296 |
Put on my shroud and rad hoses
05-15-2016, 10:49 AM | #2297 |
Test fitted the new bed wood before it it goes out to paint.
05-15-2016, 04:42 PM | #2298 |
Just scored this set of original wheels with rusty trim rings and great condition center caps from a '63. The vehicle has been in one family.
Not bad for $50! |
05-15-2016, 06:33 PM | #2299 |
05-15-2016, 07:51 PM | #2300 |
Hit the pick n pull this morning for Honda door seals,7.00 each. Jeep door checks,1.99 each ,and a clutch fan for 15.00.. Finished peel n seal on cab floor and behind tank.
