Old 07-31-2018, 05:48 PM   #2401
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1972 Chevy 4wd Longhorn Project: Never Ending Changes
I've been using this truck hauling a lot of stuff and driving it everywhere. I had my first issue at the end of June hauling my camper. My bottom turbo is pushing/leaking oil and my air filter got really dirty. I removed the top turbo to put a different turbo on but I will have to redo my piping so I cleaned everything back up and put it back together so I can continue to use the truck. I just can't haul my camper long distances with it until I rebuild the bottom turbo. (I probably won't tow the camper at all just in case)
I finally got tired of my in bed 16 gallon fuel tank and got the 19 gallon Boyd welding tank installed. I couldn't make the marker light hole work as the filler door because my fill tube is so large. I ended up putting it inside the bed and made a box around it which allowed me to put my trailer wiring socket in a better place too. I still need to finish affixing the box to the bed side but it works for now.
I also fixed the rust on the left rear corner of my bed floor. It was rusted through like most do where the bed side attaches. I cut out the rot on the cross member and installed new metal, then put the bed floor patch in. I despise the bed floor patch I got as it doesn't match the bends worth a darn. I'm on the search for a good steel floor for the next Longhorn build. I then welded the LH bed side to the floor. Soon I need to do the RH side. Someday I'll get the bed done......
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-31-2018, 06:04 PM   #2402
Dieselwrencher
Next thing on the list is to get rid of the wood console I made to house my little larry valve, and ditch the little larry valve. That SOB will get stuck and continue to add air when it is in the middle position. Not cool. I'm going to put a regular leveling valve on it with a dump valve and be done with it. Then I need to finish hooking up my gauges, and I might put on borg warner turbos and my oil filter relocation stuff later on. Like the title says, never ending changes.
My daughter rode with me to and from the car show in Oskaloosa last weekend. She passed out 10 minutes into the trip on the way home. The kids love this truck. I'm betting I'll be building them their own trucks on down the road.
I did find another project last weekend but I don't think I'll pursue it. I just don't need another project. (Is that a thing?)
Ryan
Old 07-31-2018, 11:36 PM   #2403
6BT 56
6BT 56's Avatar
Nice to see it out and working . My little guy falls a sleep in all our stuff all the time . One time he fell asleep in the back of my old ford tractor. Full metal cab. Screaming away with the snow blower going . How do they do it ??? Lol...
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 08-01-2018, 08:14 AM   #2404
watahyahknow
watahyahknow's Avatar
fillerneck looks nice . about the ribs in the floor : cant you get a metal shop to bend up a plate for you that matches the original ?
might be cheaper then cutting up an existing bed (you did say they all rust at that spot)
or buy some extra tools and make youre own :
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-01-2018, 10:37 AM   #2405
Dads79GMC
Dads79GMC's Avatar
Looking good!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 08-01-2018, 01:21 PM   #2406
jbclassix
Junk Yartist
jbclassix's Avatar
I used Boyd Welding for the fittings in the cooling system. I am very happy with them so far.
Same deal with patch panels here... I hate the fitment.
I am interested to see what you do for the suspension valve. For some reason I thought you used a standard leveling valve originally.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-01-2018, 04:58 PM   #2407
Dieselwrencher
I mainly want another steel floor and part of another so I can do another steel floor conversion in a Longhorn bed. I probably could have a patch bent by a shop but that custom one off stuff at places like that around here gets expensive.
Originally Posted by Dads79GMC View Post
Looking good!!
Thanks!
Originally I was going to put a regular leveling valve on and then I stumbled on to the little larry valves. I wanted it because it would run the front and rear individually so when I did the front I'd be set. Currently I have the RH and LH bags separated and use 1 valve to run each bag. I don't like it as much as the old leveling valve I had. I thought about putting both rear bags on 1 valve on the little larry touche', but if I'm going to make changes, it's coming off the truck.
Ryan
Old 08-08-2018, 01:07 AM   #2408
lower50's
lower50's's Avatar
At least you can still drive it with the one turbo. Gas tank looks nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-13-2018, 07:54 AM   #2409
mcbassin
Still Learning
mcbassin's Avatar
Very cool seeing you put your truck to work! Looks great towing the camper
mcbassin is offline   Reply With Quote
Old 12-10-2020, 09:59 PM   #2410
Dieselwrencher
I haven't really changed much on it. I did get the rear fuel tank installed and out of the bed. But I've just been using it and working it all the time.
Ryan
Old 12-11-2020, 08:03 AM   #2411
lower50's
lower50's's Avatar
That's OK these things happen. At least you are still driving it and loving it.
1951 MG TD
