Old 09-02-2019, 05:02 PM   #1
TKCR
TKCR's Avatar
Dyeing interior parts
I love seeing how the parts turn out after freshening them up with some dye!
Charcoal headliner trim & visors
CarmineRed headliner trim & visors
Burgundy seat garnishes
Old 09-02-2019, 05:56 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Dyeing interior parts
Nice work!
Old 09-02-2019, 05:59 PM   #3
54Caddy
GM Addicted
54Caddy's Avatar
What’s the process your using looks good!
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 09-03-2019, 02:41 PM   #4
TKCR
TKCR's Avatar
Clean & prep is the key. I clean the parts with Dawn & hot water. Then I use the SEM Soap with the scour pad. The SEM soap is the little blue bottle. Then use the appropriate Prep, wether it’s vinyl or plastic. Then the Adhesive Promoter. While that is still wet on the parts, lay down the first light coat of dye. Let that dry and then follow with additional coats, dry time in between.
If your dyeing the same color as the parts, it will only take a few coats. But if your changing the color of the parts, it will take a lot more dye to cover completely.
Old 09-03-2019, 03:51 PM   #5
lowbrow454
Active Member
lowbrow454's Avatar
Have you ever re textured any trim pieces? If so what kind of texture did you use?
'75 C10 SWB 454
'75 K10 SWB "The Gilded Turd"
'77 K5 Blazer Chalet #0661 Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=776072
'79 K10 Bonanza
lowbrow454 is offline   Reply With Quote
Old 09-03-2019, 04:06 PM   #6
TKCR
TKCR's Avatar
Not yet, but I have a few pieces that I think need that done to them. I will post it up, as soon as I try it out.
Old 09-03-2019, 04:27 PM   #7
lowbrow454
Active Member
lowbrow454's Avatar
Looking forward to it. I've seen a few companies that make the spray on texture but haven't seen many results.
'75 C10 SWB 454
'79 K10 Bonanza
Old 09-04-2019, 01:52 PM   #8
TKCR
TKCR's Avatar
Did more parts today. 84-87 Grille, more seat parts and got the visors back together. I take the little stainless steel pieces off for the dyeing, then I polish them up before putting them back on the visors.
Old 09-04-2019, 04:07 PM   #9
lowbrow454
Active Member
lowbrow454's Avatar
Looking good! Nice work.
'75 C10 SWB 454
'79 K10 Bonanza
Old 09-05-2019, 03:47 PM   #10
K25alive
Yes, those all look new! What color do you use for the grills? I have a '77 grill that is quite faded and could use a refresh. I can't tell if it was a light light gray or a silver originally.
K25alive is offline   Reply With Quote
Old 09-05-2019, 05:25 PM   #11
TKCR
TKCR's Avatar
Argent silver is the correct color.
Old 09-07-2019, 02:52 AM   #12
donw1986
Which SEM paint color did you use for charcoal interior? I dont see that option in there colors was it just black?
donw1986 is offline   Reply With Quote
Old 09-07-2019, 08:06 AM   #13
TKCR
TKCR's Avatar
I don’t use SEM anymore. They have discontinued so many of our colors for our trucks. And the colors they do have, you have to guess which one will match. So several years ago, I started using the dye from USA1 Industries. They have all the correct colors, even the hard to find colors. If you look up in the post #4, I use all those SEM products for the prep. Last bottle is the Dye from USA1 Industries, and the color I used, is Charcoal. You can get every one of these colors from them.
Old 09-08-2019, 09:27 AM   #14
mingoman
Nice work as always!
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 09-08-2019, 04:54 PM   #15
TKCR
TKCR's Avatar
Thank you
Old 09-10-2019, 03:47 AM   #16
mikelom
They look really nice! Good work!
mikelom is offline   Reply With Quote
Old 09-10-2019, 06:43 PM   #17
TKCR
TKCR's Avatar
Old 09-11-2019, 11:07 PM   #18
Shugalou
Shugalou's Avatar
Wow thanks for sharing the info...looking forward to getting to this point.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 09-12-2019, 08:49 AM   #19
TKCR
TKCR's Avatar
You're welcome. Just be patient and do all the prep steps. Good Luck. If you have any questions, feel free to ask.
Old 09-13-2019, 09:38 PM   #20
Factory Guy
Factory Guy's Avatar
Really nice job.
For texture has anybody tried spraying on Duplicolor Truck bedliner? Then painting to match?
Factory Guy is offline   Reply With Quote
