01-21-2014, 11:22 PM | #1 |
Gas tank out, sub box in?
Howdy y'all! Just curious, has anybody yanked and relocated the fuel tank in their 67-72 and custom-built a sub box to go in its' place? Really want to do this, just wanted to see some pictures if anyone has done it before.
I was thinking something like either three twelves, two fifteen rounds, or two fifteen squares (Kicker Solobarics) across the bottom, with four 5x7s up top and the amp sitting in a cutout on the box (a divit down in the box just deep enough to make the top of the amp even with the face of the box). I really want some bump in my cab, and the door speakers aren't cutting it ;D Also, where should I run the wiring? I want to keep a rubber floor in it, should it run under the mat along the transmission hump? |
01-22-2014, 12:10 AM | #2 |
Re: Gas tank out, sub box in?
There is not near enough room for 15's back there, nor do you need them. You don't even need three 12's, two 12's would have much cleaner sound and hit hard enough to rattle your brain in a cab that small.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
01-22-2014, 11:40 AM | #3 |
I have one 10" kicker L7, I have my amp turned way down it hits harder then any 10 I've ever heard. The box is ported on the passenger side and I have a 500 watt amp.
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
01-22-2014, 09:55 PM | #4 |
I took my tank out cut it out and put three Memphis 10's in it it hit pretty hard
01-22-2014, 11:25 PM | #5 |
Oh, and what about the head unit? I have a head that's similar to stock (actually, I have a video of it messing up on youtube. Here:). I want to upgrade it, but I don't want to cut the dash up, and I can't give up any space in the glove box. Any thoughts?
01-22-2014, 11:27 PM | #6 |
Well, it's just that too many of my friends have two twelves, I wanted to raise the bar some
01-22-2014, 11:36 PM | #7 |
That's similar to what I want to build, except for me one ten isn't going to cut it. :/ I'm in need of bone-rattling, earth-shaking bass lol. I have a 500 watt Bazooka amp, but I'll probably need a bigger one for three twelves, correct?
01-22-2014, 11:38 PM | #8 |
01-22-2014, 11:47 PM | #9 |
Old member
I have 2-10" shallow subs in the box behind the seat. They sound fine. The bottom picture is with the old speakers installed. You can check it out in the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=601399
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-22-2014, 11:48 PM | #10 |
Me wanna see! Dang Andy... We posted bout the same time. Nice setup!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-23-2014, 12:53 PM | #11 |
i have 1 15 in mine, cheapo box i made, it hits pretty hard though
~When In Doubt Go Lower~ |
01-28-2014, 02:18 AM | #12 |
01-28-2014, 02:19 AM | #13 |
this set up hits harder than my 2 12's in my other car.
01-28-2014, 02:21 AM | #14 |
as for the stereo, i put a deck in the regular spot. only had to a little shaving/cutting, looks good still. don't have a pic of that at the time
01-28-2014, 09:22 AM | #15 |
I was gonna say, look up ACEX here on the boards. He's got I think 4 8's and it's bangin' something fierce.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-28-2014, 10:20 AM | #16 |
01-28-2014, 10:20 AM | #17 |
01-28-2014, 10:22 AM | #18 |
01-28-2014, 10:17 PM | #19 |
I built the custom box behind the seats. The biggest thing is having the depth to fit the subs. I am running to 12in Kenwood shallows. There is a big difference in sound from the shallows in my truck to the full kenwoods 12in in my car, but having the sub 6in from your back bone helps with the feel. Also having the subs so close you need a quality sound and seal. My system goes as follows
1-kenwood head unit, 2- spr60's under the dash, 2- spr60c's behind the seat,1-MRX-F65 4-channel amp, 2-Kenwood 12in shallows,1-hyfonics amp. I want to upgrade to a better sub amp and better speakers under the dash, maybe type-x's.
_______________________________________________ A project can be finished, but a car is never done. 1967 chevy K10 step 2002 chevy Impala Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308 |
01-30-2014, 11:15 AM | #20 |
1 10",2 6x9's in cab corners,and 2 6x5's on kick panel.
84 step side 87 swb |
01-30-2014, 02:52 PM | #21 |
Have you thought about going to a center console and bucket seats?
It sounds like you want a lot of sound and I don't know if you can get it to fit without moving the seats forward. I ran my wiring along the frame and then in to the cab threw the hole that the gas line ran threw.
02-11-2014, 08:56 PM | #22 |
I thought I would take a better picture of my boxes since I had my seats out. Also, I used my boxes to hide the seat belt re-tractors that are mounted to the floor and the area behind the speakers is open leaving space for the re-tractor and belt to pass.
02-11-2014, 09:39 PM | #23 |
while i made this for my 58 it would be easy to adapt to any truck
one sub and battery on this side two amps on this side
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-14-2014, 09:50 AM | #24 |
Here's what we built. Sorry I don't have better pics. 12" shallow sub with 6x9's in the corners and some high tech (2) up front in the original spot in the dash. 1200 watt system. Sound is ok...makes me smile anyway.
02-17-2014, 05:16 PM | #25 |
Check out these new products from fesler.
1967 C10 SWB 6.8L/4L80 |
Tags |
67-72 truck, fuel tank, radio, radio wiring, sub box |
