05-17-2020, 06:27 PM | #1 |
Weekend Warrior
New To Me '66 Burb
So I picked up this '66 Burb a few days ago. I'm more or a 67-72 Pickup guy, but I like the '60-'66 burbs better than the 67-72 one.
Anyway Fast plans are lowering hopefully with a simple airride setup and LS swap. Has the original 283 in it. It was a 3speed column, but someone swapped a 4 speed in it and chopped the trans tunnel out so I'll have to repair that. supposedly was an original Cali truck. It is very solid and unmolested.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
05-17-2020, 06:44 PM | #2 |
Re: New To Me '66 Burb
Dang, that looks good!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-17-2020, 08:22 PM | #3 |
Good looking suburban for sure.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-17-2020, 08:53 PM | #4 |
But Found Her 25yrs Later!
Body and paint look naturally perfect.
And one of my favorite colors.
05-17-2020, 09:12 PM | #5 | |
Weekend Warrior
has anyone used the AZ Pro Performance budget air ride kit?
05-17-2020, 10:13 PM | #6 |
60-66 Nut
That looks like a nice original 'Burb and with the custom trim too.
05-17-2020, 11:59 PM | #7 |
Are you going to keep it in its natural beauty?
05-18-2020, 01:17 AM | #8 |
That's a winner! I particularly like the single color with custom trim look.
05-18-2020, 08:03 AM | #9 | |
Weekend Warrior
Thats the plan. Keep it as is. Like I said there is a little damage on the left rear quarter. If I decide to fix it, hopefully I can blend the paint to match. There is also some holes drilled in the roof from a previously installed roof rack that need to be addressed. PO just filled them with clear silicone to keep water out.
05-18-2020, 10:11 AM | #10 |
It's Better With Nitro
Very cool! I also have a soft spot for 60-66 Suburbans. Look forward to your progress.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
05-18-2020, 01:38 PM | #11 |
Moderator
LS Engine?
Ohhhhhh William
05-18-2020, 10:02 PM | #12 |
Weekend Warrior
Absolutely!!! Honestly want to travel in this thing and have power plus reliability. I'm a SBC fan and have had plenty of them, but LS is the way to go.
05-28-2020, 12:37 AM | #13 |
Wo what a beauty , same color as mine my 66 burb my favorite
