Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 07-30-2015, 05:19 PM   #1
pwdcougar
pwdcougar's Avatar
Epoxy primer re-coating
I was reading In The Ten Ring's thread about re-coating epoxy primers and realized my "plan" has a potential flaw.
The plan is to start with the fenders and doors one at a time before bringing the Suburban body home. They would be sandblasted, initial body work and body filler, then epoxy primer. Then they would be stored in a dry heated garage till the body work is done on the body.
The primer is PPG EPX 904. The data sheet says to top coat within 4 days. After 4 days mechanical abrasion is required before re-coating. It may be a year or more before topcoating.
Is there a sanding primer or something else I can put on that will require less sanding before topcoating? There will be more body work to do on the parts.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 07-30-2015, 05:25 PM   #2
hugger6933
Re: Epoxy primer re-coating
Go ahead a spray on some high build primer after the epoxy. Normally I don't recommend spraying the high build before storing but since your putting in a heated storage you will be fine. the reason I don't recommend it is the high build[along with any other primer other than the epoxy] will attract moisture. But since your in the dry go ahead and spray high build it will be less work.
hugger6933 is offline   Reply With Quote
Old 07-30-2015, 09:13 PM   #3
pwdcougar
pwdcougar's Avatar
Thanks Hugger
Should I stick with PPG paint or doesn't it matter?
Paul
Old 07-30-2015, 09:51 PM   #4
hugger6933
Paul I've never been a fan of crossing lines while in the middle of a job I use PPG stuff primarily Omni to be more matter of fact. I use the MP primers 174 and 282 that is the epoxy and high build primers and absolutely LOVE them. The use of Omni over the top line PPG stuff can save you anywhere from 10% to 90% on materials.
Old 07-30-2015, 10:30 PM   #5
pwdcougar
pwdcougar's Avatar
So the omni high build will work ok with my EPX epoxy then? Also I am kind of new at paints what are MP primers?
Thanks again
Paul
Old 07-31-2015, 07:32 AM   #6
hugger6933
Yes it will. MP is just the part number prefix on the Omni primers like MP282 is the high build.
