04-19-2018, 04:52 PM | #1 |
Advice On Removing Starter 350 Trans Cooler Lines ?
Need to remove starter but the transmission cooler lines are running below it, can yet it out without unhooking lines, out the top ? Very frustrating
71 C-20 07 Magnum RT AWD |
04-19-2018, 05:04 PM | #2 |
Re: Advice On Removing Starter 350 Trans Cooler Lines ?
I just push them to the side. They move hard but they do move. I have never had to disconnect them to remove a starter.
04-19-2018, 05:27 PM | #3 |
Thanks ! I was hoping you could pull it out the top ? Also couldn’t budge the retaining bolts one bit ?
04-19-2018, 05:35 PM | #4 |
The starter bolts? Or are you referring to the trans lines?
04-20-2018, 09:59 AM | #5 |
Starter bolts to block.
04-20-2018, 10:51 AM | #6 |
They are knurled so they wont back out. Take a breaker bar to it. With a long enuff bar they will come off. Lefty Loosey! Good Luck!
04-20-2018, 11:08 PM | #7 |
Msgt USAF Ret
Why do you have to pull the starter and please don't break the bolts?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
