Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 04-10-2017, 11:24 PM   #1
Silvr94jd
94 Build
I'm new to the forum. i have a 94 c1500 that im taking out the 4.3 and dropping in my 1995 454. which leaves me with a question about what tranny should i use?
Silvr94jd is offline   Reply With Quote
Old 04-12-2017, 07:14 PM   #2
SCOTI
SCOTI's Avatar
Re: 94 Build
Auto or stick guy?
4l80e would be my top choice. A 700r4 could be built up but they're known to not survive long behind big power (there are always exceptions).
A Tremec TK600 5spd/OD or T-56 if you want a stick.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-15-2017, 07:43 AM   #3
Silvr94jd
Re: 94 Build
Thanks Scott, the Donor truck i bought has the 4L80 with it. It seems like a very good match. I hope to set the motor in a couple weeks.
Old 06-16-2017, 08:34 AM   #4
Silvr94jd
Re: 94 Build
Okay here it is I have the 454 in my truck now with a 4l80 transmission my truck is a 1994 Chevy pickup standard cab two wheel drive I'm looking to find out what yoke I can use with that transmission to hook up my drive shaft to the rear end if somebody out there can help me I'd appreciate it you're a driveshaft maker in San Diego here is telling me it won't work.
Thank you JD
