Old 09-30-2020, 10:41 PM   #1
Apache38
New Fly wheel for a stroked 350
I've been reading posts and web articles and I can't seem to find a definitive answer. About 10 years ago I did a new build on my 72 2-bolt with new pistons and rods on a 400 crank. A little clearance on the oil pan rails and it runs really well on pump gas and my older fuelie heads - no complaints.
Here's my dilemma. I used the original flywheel from my 59 with a crank balance weight and a new balancer and then had it all balanced. Love it - it's great, but the starter gear is really beginning to give me problems and wear on the bendix gear.
Can I just buy a new aftermarket flywheel that's externally balanced or do I need to find a shop to somehow match the balance of the old one? or should I buy a regular flywheel and use the balancer weight I bought from Summit?
59 Apache 3805 (1 ton Panel)
Stroked 350, SM465, NP-205
Corporation 14 behind Dana 60
Apache38 is offline   Reply With Quote
Old 10-01-2020, 01:27 AM   #2
clinebarger
Re: New Fly wheel for a stroked 350
Have a new Ring Gear installed on the original flywheel.
clinebarger is offline   Reply With Quote
Old 10-01-2020, 01:30 AM   #3
Greasey Harley
Greasey Harley's Avatar
^^^yup^^^
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 10-11-2020, 01:05 AM   #4
burnin oil
What was said above. You can also look at the old flywheel for drill or grinder marks where they balanced it. If there are none then a replacement flywheel should be fine.
burnin oil is offline   Reply With Quote
Old 10-19-2020, 06:18 PM   #5
crazy longhorn
Fabricate till you "puke"
Listen to Cline....do not mess with the balance on that engine! Another trick (old school), was to take the ring gear off, & flip it.....assuming, that there were no teeth completely missing Best of fun, crazy L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-19-2020, 06:24 PM   #6
geezer#99
geezer#99's Avatar
Well holly crap Batman!
Mr. shorthorn lives!
And flipping ring gears too!
We gotta stop sharing those old skool ideas.
Old 10-19-2020, 06:33 PM   #7
crazy longhorn
From one old geezer to another....Yes I am still here, just spending more time working on the house Do you think that we should talk about welding the teeth back on the ring gear, &chopping them in with a die grinder Shorthorn
Old 10-19-2020, 06:40 PM   #8
geezer#99
geezer#99's Avatar
Nah!
Too confusing for the ‘let’s just buy a new one’ crowd!
Good to see you missed the corona!
We been lucky too.
Living on a big island helps. We had 129 cases and 3 died.
Old 10-19-2020, 07:11 PM   #9
geezer#99
geezer#99's Avatar
Pm sent Mr. Shorthorn.
