05-15-2014, 08:30 PM | #1 |
1971 c20 4x4
I'm new at this looking for help I bought a 71 C 20
4x4for my 15 year old son we have one year to get it ready would like to switch the front end out for more modern disc brakes can anyone help me with what will be an easy swap I was told up to 1984 will bolt in this anyone know for sure |
05-15-2014, 09:04 PM | #2 |
Re: 1971 c20 4x4
A 4wd 3/4 ton is a K/20. C/20 mean 2wd. If your truck is a '71 K/20 it should already have disc brakes on the front. I'm curious what you might actually have. As far as the 10-bolt axles used through the '91 V2500 (post-86 3/4t 4wd...ok,'87s were V20s) crewcabs and Suburbans goes,yes,it's a direct bolt-in
05-16-2014, 01:45 PM | #3 |
Re: 1971 c20 4x4
Special K sorry this the first chevy I have owned and currently I have it off of my property to surprise my son on his birthday so I thought it was a c 20 the guy I bought the truck from had told me the last time they did brakes they had trouble getting parts and they didn't work very well truck is also lower geared than I would like so my thought was to swap out for the most modern axles that would be a quick and easy
05-16-2014, 05:09 PM | #4 |
Re: 1971 c20 4x4
As Special-K mentioned, '71 should already have the front disk brakes which from my understanding are pretty much the same all the way up to '84ish when they went from the 7/16 banjo fittings to the 10mm. My assumption is that brake parts for the front axle are still plentiful.
The rear axle may be a different story though, depending on what it has in it. I know parts for the Eaton rear axles are getting harder and harder to find. On mine, I replaced both axles because mine had 4-wheel drums and mismatched gear ratios. I found a front axle out of an '84 3/4 ton and the rear is a full floater out of a '91 crew cab. They are now both the 4:10 gearing, and other than moving the rear shock mounts on rear axle were a direct bolt in. |
05-16-2014, 05:12 PM | #5 |
Re: 1971 c20 4x4
Oh, and BTW...welcome to the forum! There are A LOT of knowledgeable and helpful people here that are willing to help...oh and make sure you start a build thread if you tear into it
05-16-2014, 06:29 PM | #6 |
Re: 1971 c20 4x4
Thanks for the help like I said I'm new to gm trucks so I might be asking some dumb questions in the next year getting this ready for the boy
Chad |
05-16-2014, 06:46 PM | #7 |
Re: 1971 c20 4x4
Well you picked a great vintage :-). There are no dumb questions. Just be careful, this site is addicting and hard on the wallet
05-16-2014, 08:17 PM | #8 |
Re: 1971 c20 4x4
definitely no dumb questions here, im proof of that lol I USE to love the 2WD C's but since found a love for the K trucks, so please post some pics when time allows
jason
70 Chevelle | 71 Camaro RS/SS | 71 K20 | 98 TransAm | 10 Ducati 848 |
05-17-2014, 08:31 PM | #9 |
Re: 1971 c20 4x4
My son and I just finished his 71 K20, if you need any help or advice feel free to contact me, we are "just " over the pass. Parts for the front brakes are easy to come by, as was mentioned earlier, if you have the eaton rear end, they are a beast. We converted the eaton rear to disc brakes for the same price that it would have cost to rebuild the drums. You guys have a ton of options in this area. Good luck with the build and welcome to the forum.
