09-08-2019, 07:38 PM | #26 |
Re: Stubborn Engine Problem
IDK, symptoms sound like a lean misfire due to a lean carb/accelerator pump
Most aftermarket carbs out of the box are pretty dang lean. That's where I would start
09-11-2019, 04:34 PM | #27 |
One thought on the hesitation and/or misfire... Are you comparing your truck to new vehicles which have nearly zero misfire, or to old cars that almost always have a little of it? When I first started driving most of our cars had A LOT of hesitation, especially on those cold sub-zero Minnesota mornings. So I'm pretty tolerant of a bit of it.
Having said that, Holley has a kit to switch in more aggressive accelerator pump cams. I've done that before. It worked great. If I remember correctly, the yellow one is the biggest and most aggressive. https://www.summitracing.com/parts/h...BoCKwAQAvD_BwE
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
09-12-2019, 11:43 PM | #28 |
Is the problem just at constant, light throttle? I believe you mentioned it wasn’t an issue when mashing the throttle. If you shift down a gear while running the same speed where the problem shows up, does it go away?
09-13-2019, 01:47 AM | #29 |
09-13-2019, 07:20 AM | #30 |
It is a pretty hot engine. I have never had to tune an engine with a rowdy cam like this. That must be the problem here. That performer RPM isn't an air gap is it? Since the carbs aren't making a difference I think I would plunk down $50 and try a Skip White Distributor for the heck of it. Good luck.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-16-2019, 06:56 PM | #31 | |
The sound happens not just when i move the throttle (i.e. when the accelerator pump activates), but also when I hold the throttle for cruising just off idle. Is it possible it was too rich into the primaries (hence the jetting down helping), but too lean just off idle? I know one answer to all this would be to get an AFR gauge. But I'm just worried I'll be throwing yet more money at something that may not even be part of the problem. |
09-16-2019, 06:59 PM | #32 |
Correct. It goes away once I'm into the primaries. It is constant at light throttle, although it doesn't have a noticeable pattern, consistent with RPM for instance. It seems random. Down shifting does make it go away as the throttle opens further.
09-16-2019, 07:02 PM | #33 | |
09-16-2019, 11:21 PM | #34 | |
09-17-2019, 11:13 AM | #35 | |
Here's a low resolution version: https://www.youtube.com/watch?v=CJOx76DC0eM You can find better versions for free, but the best way is to subscribe ($5/month) to MotorTrendOnDemand. https://www.motortrendondemand.com/d...ck/0_jerfe1z5/
09-17-2019, 12:38 PM | #36 |
Hmmm. I never tried going the other way with the air bleeds. I will try it and see what happens. Thanks.
09-17-2019, 12:39 PM | #37 | |
09-17-2019, 12:47 PM | #38 | |
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
09-17-2019, 02:15 PM | #39 |
I totally understand. But I was so hooked on it I subscribed so could get early episodes. I've been paying my $5 since way before they left YouTube. Addicted. ;-)
09-20-2019, 06:23 PM | #40 |
So I tried two things yesterday.
1. I tried going richer on the idle circuit by going to a smaller air bleed on the idle circuit. No change. Not in the slightest. 2. The quick fuel has a set screw for adjusting when the vacuum secondary comes in instead of changing springs. I set this all the way in for the slowest in coming in. No change at all. I really feel like it is still an ignition issue. The most luck I've had was swapping plug wires. I had gotten it to where the miss was almost imperceptible. Then I swapped intake manifolds to get rid of a vacuum leak and now the plug wires do not seem to make any difference. I've gotten it much more drive-able now by getting the timing right, but it just doesn't sound right. I have a new torque converter on the way. That will be a big project. |
09-20-2019, 07:32 PM | #41 |
I'm grabbing at straws here, but have you checked for additional vacuum leaks? If someone had suggested that to me I'd be like "What are you kidding? I'm very careful and methodical. That's very unlikely." But recently I discovered that I had left off a cap for a 3/8" hose barb hidden under the back bowl of my carb. Once fixed, my idle really straightened out.
09-20-2019, 08:09 PM | #42 | |
10-01-2019, 11:46 AM | #43 |
That's a fair point. I was grabbing at straws. But sometimes in troubleshooting we need to revisit things we thought we knew for certain, especially if we haven't yet solved the problem.
10-01-2019, 01:06 PM | #44 |
The only thing left to do is to try the old distributor bottom half. After that, I think it's time to take it to someone more knowledgeable than myself (which isn't hard).
05-11-2020, 02:03 PM | #45 |
There's nothing I hate more than reading through someones thread where they have a similar problem and getting to the end and there's no resolution. So I'm pulling this thread from the grave and giving it some resolution.
This problem was entirely timing. I have had trouble getting an accurate reading with my timing light and the DUI distributor. I was also thinking that the TDC mark on the damper was incorrect. I bought a TDC tool to insert into the spark plug hole and confirmed the engine builder's mark is right on. I was looking at youtube timing and ignition videos when this guy plugged this distributor from Progressive Ignition. This distributor gets rid of all the mechanical advance portions of the distributor and replaces that with an electronic version of advance controlled completely from your smart phone or tablet. It's a little complicated for me to explain but there are videos on the website which better explain it. https://progressionignition.com/ The ability to change the timing curve on the fly is huge. I think what my problem was, besides not getting accurate timing, the mechanical advance was coming in too early (too light of spring) at partial throttle. This new distributor has completely cured this and it's actually pretty fun to play with the timing so easily on this thing. My only concern is that in 10 years is the company still around and making the app available on the latest hardware? Impossible to know. But for me, this cleared up my problem completely. |
05-12-2020, 08:56 AM | #46 |
I have heard some buzz about these new distributors that can be adjusted from the drivers seat. I have never had the urge to do that. I guess I'm too lazy. It would be pretty cool at the drag strip though. The old $50 Skppys have never done me wrong.
05-12-2020, 04:54 PM | #47 |
Drew, just curious- did DUI/Performance originally tune the distributor on their machine specific to your truck specs? I am surprised the timing curve would have been that far off. 24 degrees of mechanical does seems like a lot though for a recurved distributor compared to some of the timing curves recommended here.
That kill switch feature on the Progressive distributor is pretty cool. |
05-12-2020, 05:57 PM | #48 |
I gave DUI all my engine specs. 24 degrees at 3000 is etched right on the underside of the distributor. It very well could have worked fine if I was ever able to get it accurately timed. I have two different timing lights, and 3 sets of plug wires trying to get it right, and it just never flashed consistently. I never had any confidence that I had it exactly where it should be. It was maddening.
05-13-2020, 08:14 AM | #49 |
Now that it’s electronic, what timing numbers are you running now?
Timing numbers like initial, when does mechanical start and how much, mechanical all in timing and at what rpm. |
05-13-2020, 08:44 AM | #50 |
Never mind
