Old 02-06-2020, 09:37 AM   #1
moregrip
moregrip's Avatar
1983 garage build
finally starting to get some work done on this 83 longbed thats been sitting at a stand still for the last 2 or so years! I'll be working out of essentially a 2 car garage. My "target" "official" start date is March 1st; got a few preparations that still need to be addressed but couldn't stop myself
overall it has a very clean and dent free bed floor, only two dings I can see; I believe it had a large camper in the bed most of its life
and a surprise rear cab dent of course
the better of my two longbed bedsides/little heavier than the shortbed style
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 02-07-2020, 09:50 PM   #2
moregrip
moregrip's Avatar
Re: 1983 garage build
flashback friday: here she is shortly after I brought her home from the Nevada desert; essentially rust free but definitely has a few challenging dents I'll need to deal with
Old 02-08-2020, 07:10 PM   #3
moregrip
moregrip's Avatar
rollers showed up today.....if and when I get the blue 76 running, these will surely help in getting her safely over to a temp home = more room for this 83 project!
will mount these on some 15 x 6-1/2 steel wheels I've got laying around, look like sport wheels but not (made in Canada type)
Old 02-09-2020, 02:53 PM   #4
moregrip
moregrip's Avatar
tires mounted on my wannabe sport wheels. I'll get these put on the blue 76 today and then start working on trying to get it running (been sitting for 2 years), should be fun right!
Old 03-13-2020, 11:37 AM   #5
moregrip
moregrip's Avatar
couple of updates:
"FINALLY" got some real power going on in the garage; installed a sub-panel with two dedicated 30amp 220 volt plugs and two dedicated 20amp 110 volt 2-gang plugs. ok, nothing earth shattering going on here but sometimes the little things make a big difference right!
Also, bought another four, 4 foot shop lights I'm going to try and strategically hang over work areas to help fill in some of the darker areas.
And, I'm in the process of putting up a couple of 16" deep (high mounted) shelves to store some of my power tools in an effort to better utilize space available.
other than that, I have some marvel mystery oil on the way to soak some sbc cylinders that have been sitting a while = never a dull moment!
Old 03-13-2020, 07:39 PM   #6
moregrip
moregrip's Avatar
don't get jealous; here's the power-plant I'll be working with! 250 FTW!!
Old 03-14-2020, 09:15 AM   #7
wixthedog
wixthedog's Avatar
Keep up the good work and updates!
I mounted a few 4' lights vertically in some small buckets of concrete. That way I can move them around as needed. I learned it from an old paint guy that needed light wherever he was and it has worked well for me.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 03-16-2020, 12:42 PM   #8
Love you are staying with the six banger. I just got mine converted to old style heads and a few mods.
Old 03-17-2020, 08:15 AM   #9
moregrip
moregrip's Avatar
thanks! still configuring the garage a bit but making a little progress everyday!
Old 03-17-2020, 08:16 AM   #10
moregrip
moregrip's Avatar
Wanted to work on something I'm less familiar with and they are cool in their own way!
How do you like your AC bracket?
Old 03-17-2020, 08:22 AM   #11
Seems good so far. It is hard to get my fat fingers in around the HEI cap, but it was akward with the factory AC bracket also.
Old 03-17-2020, 11:06 AM   #12
moregrip
moregrip's Avatar
I have the Davis alternator and power steering brackets as well; was thinking about getting their newer AC bracket
https://www.ebay.com/itm/10088-LOW-P...-/223716072126
Old 03-17-2020, 04:35 PM   #13
I had not see that one or I may have gone with it also. It will still be "compact" around a standard HEI cap, but it will work. I do like their quality. I kinda wish I went with the one that has power steering on top and alt on bottom like it was in stock configuration, but it works out this way. BTW, plenty of clearance with the hood with the regular one also.
Old 03-17-2020, 09:52 PM   #14
moregrip
moregrip's Avatar
I think I have the same arrangement as you, power steering down low, alternator up high.
I have the stock HEI distributor but may run a stock points type housing with electronic trigger; that might buy me some room; nothing in stone except I need A/C in this desert I live in!
Old 03-18-2020, 05:11 AM   #15
LT7A
So cool to get started on a truck that has been waiting its turn for a couple of years. Interested to hear the plan and watch the progress. It appears that piston #1 has been "strategically lightened". Is the plan to similarly "lighten" the rest of them to maintain balanced forces on the crankshaft?
Old 03-18-2020, 04:48 PM   #16
moregrip
moregrip's Avatar
The previous owner was doing me a favor! Aero pistons FTW!
I have an idea rattling around in my head; we'll see how it plays out. Might even be cool when its all said and done.
Plan for the engine is to try and get 300-350 crank HP from the little 250 which means the stock cast iron cylinder head will need some work!
Starting with the frame/chassis and going from there
Old 05-03-2020, 09:39 PM   #17
moregrip
moregrip's Avatar
got a little work done on the round light squarebody this weekend; removed all A/C components, all wiring, bench seat, both doors, steering column, windshield, other misc items. Bolts bagged and tagged.....time for some R&R.
Old 05-09-2020, 03:11 PM   #18
moregrip
moregrip's Avatar
bed floor and hood made it to storage today.....looks like I got some scrubbing to do!
Old 05-09-2020, 06:18 PM   #19
Corts60
Just here to tinker
Corts60's Avatar
Wow! That is a very clean truck! Everything looks in great shape, albeit a little dirty. It'll be cool to see what you do with it.
Old 05-10-2020, 07:48 AM   #20
moregrip
moregrip's Avatar
Thank you, she's a $1000 dollar desert truck I'd seen for sale on the side of the road for years. I bought the truck just after I retired from the Navy in 2016; towed it home on a u-haul dolly. It's taken me a good bit of time to start wrenching but at least she's well underway now! Lot's of ultra fine desert sand throughout!
Old 05-21-2020, 01:41 PM   #21
moregrip
moregrip's Avatar
another small step forward:
Old 05-21-2020, 01:55 PM   #22
Warrens69GMC
Warrens69GMC's Avatar
Nice! I have been looking for a I6/SB with air
Old 05-22-2020, 12:44 AM   #23
moregrip
moregrip's Avatar
I've never seen one like that but I know they exist! Good luck!
Old 06-01-2020, 12:15 PM   #24
moregrip
moregrip's Avatar
one side down; used a Mayhew center punch and 3 drill sizes finishing up at 19/64"....seems to be a good size for knocking the heads off with an air chisel and allowing enough room for variance so as to not get into the frame and/or bracket metal.
Old 06-01-2020, 03:45 PM   #25
rodstored-72
chevy truck fan
rodstored-72's Avatar
more grip,
Nice job. I am waiting on my kit from summit & then will begin the drop proceedure. I will use the above info on my purches as well. Thank you for the tips!
rodstored-72 is offline   Reply With Quote
