06-15-2002, 09:24 PM | #1 |
will 73 up gears work in 67-72 and visa versa
Just want to know if I can put gears from my 69 -3.73 in a 73 up posi-tract housing:
06-15-2002, 10:44 PM | #2 |
If both rear axles are 12 bolts and if both are the same series. 3.73 and up requre a 4 series carrier in trucks and less than 3.73 is a 3 series. If you want to put 3.73 on the posi and it is 3.07 you can buy a thick gear from Richmond. That's the way my 4.10s are, mounted to the original 3.07 Eaton posi in my JImmy.
06-16-2002, 06:21 PM | #3 |
Hey, thanks Mike for the info . I never had any idea the ratio had any thing to do with it.
Chevyman 68 C/10 |
