01-21-2020, 01:02 AM | #1 |
chevy truck fan
brake booster question
ok guys.. I give up I have looked & looked & I am not able to find what the nut size (mainly the stud size) is for the brake booster bracket. I had to replace the(6) nuts that hold the booster (bracket) to the firewall?? this could be a trivia question for Keith Seymore I bet!!
thanks!! Last edited by rodstored-72; 01-21-2020 at 03:46 PM. |
01-21-2020, 11:06 AM | #2 |
Re: brake booster question
for some reason mine were metric ,1980 truck
01-21-2020, 01:15 PM | #3 |
Do you have a way to measure the stud diameter? My truck doesn't have a booster, but I'd suspect your threads are either 3/8-24, 3/8-16 or, if metric 8mmx1.25 or 8mmx1.00.
I find thread gauges like these to be indispensable:
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-21-2020 at 05:33 PM. |
01-21-2020, 01:47 PM | #4 |
Do you still have the nuts?...if so take them to fastenal or a bolt store
Thread gauges like Mike showed really come in handy..
01-21-2020, 03:45 PM | #5 |
chevy truck fan
mike,
thanks!! I "think" I have a friend that has a thread gauge. No I do not have the the original nuts, i believe they might have been "tossed out" on accident. I wanted to clean the studs up but don't know the size to get to run over them & then replace the nuts with new.... It was my bad during the teardown process- I meant to keep them though....aarrrggg I tried looking in some e-manuals & such, but to know avail...... |
01-26-2020, 04:53 PM | #6 |
chevy truck fan
well, I dug through more boxes and finally found them. I do believe they are metric, but the nuts seem to “feel” good in my 3/8-16 threader. so, i chased them and then proceeded to install. i still would like to know the answer.... hoping this might be worthy of keith seymore to chime in... LOL
thanks, I will update my thread with pics too |
02-02-2020, 02:59 PM | #7 |
The nuts are crushed a little keep them from backing off (so the holes are not totally round) If you can't factory use plastic insert nut( locking nuts) If you have headers use lock washers nuts. Or there is type that has 4 small cuts at the top of the nut squeeze lock. I think 3/8 studs, yes thread gauges come in handy more then you think.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
02-03-2020, 11:11 AM | #8 |
chevy truck fan
PONTIAC,
did not know that... for extra measure could a person use threadlock to help with security for them?? I am finding that a thread gauge might be a good "tool" to go ahead & invest in... |
02-03-2020, 02:02 PM | #9 |
If you have lock nuts theres no need for thread locker
02-04-2020, 10:42 AM | #10 |
chevy truck fan
Mongo,
I didn't think about that.... good suggestion, I also like how they look too... thanks!! |
