Old 03-19-2018, 10:19 AM   #1
Novicecarguy
69 Chevy 250 motor
Help! After reading multiple threads I can not fix my problem. I have a 69 Chevy C20 with the 4.1 L 250 with a Rochester monojet Gm.
Issue is every time I shift and put the motor under load at low rpms the motor spits and stumbles just for a second.
Here’s alittle back ground.
Coil replaced with MSD baster2 and ballast resistor
New spark plugs and wires
Installed a fuel filter
Cleaned out carb mainly just the float bowl
New distributor cap and rotor
Here’s how it began
Last week my truck died on the side of the road so I got looking under the hood and found the wire off the starter cilinoid to be melted and split apart( wire went to dash and coil) so I did a bush fix and got her home and completely replaced the wire. All running good at this point. A few days later I installed a fuel filter before the pump. All was good until I found the fuell gauge stuck at the 3 o’clock position. Fixed that now back to square 1. So I proceeded to install a new coil plugs and wires along with cap and rotor motor now running a lot better. BUT found a wire smoking at the plug as it enters the dash so I found I needed the MSD ballast resistor. So again all running good until I get on the road and the motor spits and almost hesitates. So I go through countless threads and nothing is working!
Did I do something wrong? Do I need to look more at the simple stuff?
Where do I begin?
Any help would be appreciated!
Novicecarguy is offline   Reply With Quote
Old 03-19-2018, 11:33 AM   #2
Wrenchbender Ret
Re: 69 Chevy 250 motor
Make sure the accel. pump in the carb is working. With the engine off, look down the throat of the carb & work the throttle. A squirt of gas should squirt into the throat on each stroke. There is a little wire link that goes from the throttle shaft to the accel. pump lever. Often that link falls out of the hole. You might need to o-haul the carb & check the float level.
George
Wrenchbender Ret is offline   Reply With Quote
Old 03-19-2018, 11:36 AM   #3
Novicecarguy
George
Old 03-19-2018, 11:40 AM   #4
Novicecarguy
Originally Posted by Novicecarguy View Post
So I checked the carb last night it looked like there was PLENTY of fuel going in when I checked it with the truck off. Also checked to see if the fuel pump was still good I had a ohhhh fuel to fill a Gatorade bottle with in 30 seconds. Pulled the carb off and found a lot of junk in the float bowl so I cleaned it and reinstalled the carb. It seemed to run a lot better but still under load it would hesitate
Old 03-19-2018, 11:52 AM   #5
RichardJ
melted wires, smoking wires and what the hell did a bush fix entail?
You didn't specify so I assume it still has a points ignition. it sounds like the wire you ripped out was the original ballast resistor wire, which would explain the need for the MSD ballast resistor.
Running without the resistor would burn the points or at least cause severe pitting. Replace points and check dwell and timing.
Looking at other areas (carb) and throwing parts at an unknown problem will send you in the wrong direction. Work one problem at a time.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 03-19-2018, 12:06 PM   #6
Novicecarguy
Old 03-19-2018, 12:09 PM   #7
Novicecarguy
So I was planning on replacing the coil plugs and wires reguardless
The old coil had its own ballast which was removed when I put the new one on. The melted wire happened prior to changing all that out.
The wire was run to the ignition from the starter cilinoid which another wire was on the same pole one the cilinoid which went to the coil all running fine after the wire was replaced. Not my issue.
Old 03-19-2018, 12:11 PM   #8
Novicecarguy
When you say points what are you referring to?
Old 03-19-2018, 01:16 PM   #9
harpo231
harpo231's Avatar
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-19-2018, 04:06 PM   #10
prodjay10
If your truck was sitting for a long time, you may need to clean the gas tank. I had that same issue. While the tank had been cleaned, it wasn’t clean enough. I kept having to remove the carb, take it apart, and clean it using carb cleaner and thin wires to run down the little ports. It would run fine for a while then start hesitating and running like crap after a while.
It finally started running really well after all the junk came out of the tank.
prodjay10 is offline   Reply With Quote
Old 03-19-2018, 05:59 PM   #11
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Red face Re: 69 Chevy 250 motor
Your starter solenoid should have probably a purple wire on the small post closest to the engine and the wire running to the ignition connects to the other small post. One wire on each post not 2 wires on one post.
CaptRMW is offline   Reply With Quote
Old 03-19-2018, 09:48 PM   #12
phat69
https://www.youtube.com/watch?v=W94iksaQwUo
Stop working on the truck until you have educated yourself. on how it all works.
Replace the points and condenser. Or repalce them with a magnetic pick up.(recommended)
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
Chinese HEI's are junk.
Try removing the fuel filter before the pump. The pump is gravity fed.
phat69 is offline   Reply With Quote
Old 03-19-2018, 10:35 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup. Purple wire to "S" terminal, yellow wire to "R" terminal. They should never be on the same terminal.
~Steven
Simi Valley, CA
Old 03-19-2018, 10:44 PM   #14
poway
To eliminate any fuel problems, get the number off of your carb and order a rebuild kit and rebuild the carb. I purchased mine from Quadrajet Parts for less than $50.00. I would also find a good clean replacement fuel tank if yours is rusted. I put a fuel filter before the fuel pump and after the fuel pump. Some say not to install a filter before the fuel pump but I haven’t had any problems. Check the filter sock on your sending unit as well. Good luck!
poway is offline   Reply With Quote
