Old 12-09-2018, 02:24 PM   #176
joedoh
joedoh's Avatar
Re: 1948 Chevy project
that is looking super pretty man!
Old 12-09-2018, 03:48 PM   #177
J48chevy
J48chevy's Avatar
Yes swivel joint at both ends worked out well.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 12-09-2018, 03:49 PM   #178
J48chevy
J48chevy's Avatar
Joedoh thank you. Long slow process for sure but learning as I go.
Old 12-10-2018, 11:52 AM   #179
99 to Life
99 to Life's Avatar
keep at it, don't give up.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-10-2018, 12:25 PM   #180
J48chevy
J48chevy's Avatar
Yeah definitely not giving up. Getting to that point now of wanting to hear it run for the first time.
Old 12-10-2018, 01:03 PM   #181
99 to Life
99 to Life's Avatar
yeah hearing the engine run is a big push in a build for sure. you'll get there.
Old 12-14-2018, 05:56 PM   #182
Root2812
Root2812's Avatar
Originally Posted by J48chevy View Post
And one more.
Whats your manifold to frame clearances like? You look like you have lots of room in the picture with the steering linkage. I think my engine is a little further back than yours but one manifold hits the frame and the other is really close. Looks like we have the same hooker manifolds too. I'd like to hear about how much space you have and if you have the motor centered.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 12-14-2018, 06:35 PM   #183
J48chevy
J48chevy's Avatar
Yes stock firewall and motor is centered. Both headers have plenty of clearance to the frame. I did mount motor up higher to get the stock LS oil pan clearance on bottom. Bottom of oil pan is now in-line with the MII crossmember. I do know when I do the exhaust that the passenger side will be close to the frame but should clear ok. Steering linkage I have about inch or so of clearance.
Old 12-16-2018, 10:21 PM   #184
Root2812
Root2812's Avatar
Thanks. I read your post and then went and looked at mine. I'm sure that since your engine is higher thats why you don't have the same problem as me. My exhaust just barely rubs the frame at the flange so if it were an inch higher I'd be ok. Thank you for the info.
My 1950 Chevy build
Old 12-17-2018, 11:11 AM   #185
99 to Life
99 to Life's Avatar
I mounted my LS on stock frame 5" off frame. Kept the stock truck oil pan and gave nice clearance for headers. Trans tunnel was minimal.
Old 12-27-2018, 08:24 PM   #186
J48chevy
J48chevy's Avatar
Putting on motor parts. New ICT kit for moving the compressor in away from inner fender and also the ICT kit to relocate alternator down and give me more space between motor and radiator. Should work out great.
Old 12-27-2018, 08:27 PM   #187
J48chevy
J48chevy's Avatar
Also went with different steering wheel. Starting to look more and more like a truck every day.
Old 12-27-2018, 09:01 PM   #188
joedoh
joedoh's Avatar
you should be proud, that looks great
Old 12-27-2018, 09:20 PM   #189
J48chevy
J48chevy's Avatar
Thanks. Learning as I go.
Old 12-27-2018, 10:01 PM   #190
99 to Life
99 to Life's Avatar
looks great
Old 12-27-2018, 11:48 PM   #191
Advanced Design
Advanced Design's Avatar
Very nice!
Advanced Design is offline   Reply With Quote
Old 12-28-2018, 12:05 AM   #192
oldman3
oldman3's Avatar
Looking great...Jim
oldman3 is offline   Reply With Quote
Old 01-02-2019, 02:32 PM   #193
Brads49
very nice truck! great work!
Brads49 is offline   Reply With Quote
Old 01-04-2019, 02:20 AM   #194
caseyjones
Just wanted to say great work, and thanks again for the detailed photos of the steering setup - they helped a ton on the work I did on my truck last week. Good tip on the accessory brackets too, I'll be needing those on my truck.
I see you switched to coil-overs on the front at some point. what spring rate did you end up using on the coil-overs?
caseyjones is offline   Reply With Quote
Old 01-04-2019, 09:24 AM   #195
J48chevy
J48chevy's Avatar
That is what I love about this site. So many awesome projects and usually someone has been thru what we are trying to accomplish. Haha. Anyway my coil over kit is the QA1 kit from speedway. I went with the 600 spring rate. Have not had it on road yet but did have it on floor with everything bolted on. Seems ok.
Old 02-03-2019, 12:32 PM   #196
Brads49
I just received the same IFS from Southern Rods for my '49. Thank you for posting the pictures of your install it will help me to get mine installed!
Old 07-06-2019, 05:08 PM   #197
J48chevy
J48chevy's Avatar
Well still at it. Haven’t had much time but starting to make more progress. Hoping entire front and interior done in the next few weeks. Then exhaust and ready to fire it up. Really hoping to have it done by winter. Will see.
Old 07-06-2019, 05:10 PM   #198
J48chevy
J48chevy's Avatar
Engine coming along. Did I mention before that aftermarket body parts really suck. Lots of work to get the front end lined up for sure.
Old 07-08-2019, 11:58 PM   #199
99 to Life
99 to Life's Avatar
getting there. I couldn't imagine working with repops for the front.
Old 07-09-2019, 07:45 AM   #200
J48chevy
J48chevy's Avatar
I wouldn’t recommend it at all. Spent a lot of $$$$ on fenders and the drivers side I had to split by the cab and add material so it would fit. Not to mention the grill won’t line up without making adjustments to both inner fenders as well as the fenders. Lots of making new holes for sure. But then again that is the custom work we all deal with. 🤦🏼*♂️
