04-06-2020, 05:35 PM | #1 |
Firewall replace??
I need to replace the firewall and have no idea how I'm going to hold it in place to plug weld it.
Does anyone have any tips and tricks for doing this? Thanks
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-06-2020, 06:13 PM | #2 |
Re: Firewall replace??
Use Cleco clips or sheet metal screws.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
04-06-2020, 07:29 PM | #3 |
If your doing a overlapped seam , then Clecos X2....all you'll have is 1/8 holes where they were..start in the center and work out to the ends
04-06-2020, 08:55 PM | #4 |
I learned to use clecos when I worked at Boeing in 1966 and they are great for holding overlapping panels. We would use the pre drilled rivet holes for them on aircraft panels.
They are spring loaded so you can't get them hot. I got a kit off Ebay a year or two ago to use on overlapping panels.
04-11-2020, 12:55 AM | #5 |
I agree clecos the best way but you can also use self tapping screws to hold a panel in place where clamps don't work. In this pic you can see the clecos holding my firewall in place
My build- 51 Chevrolet |
04-11-2020, 08:08 AM | #6 |
Thanks guys. I will try them.
04-11-2020, 08:19 AM | #7 |
04-11-2020, 09:09 AM | #8 |
I love the arched look of the AD firewalls.
I want to move my engine back slightly , But I know I'll have some intake clearance issues. |
04-11-2020, 10:59 AM | #9 |
Thanks, You can see how I built it if you look at my build
04-11-2020, 03:43 PM | #10 |
I have heard of guys using a steel wheel barrow tub for an engine set back in the firewall. already formed to look like it was supposed to be there for the classic year.
https://www.bing.com/images/search?v...jaxhist=0&vt=0 |
04-12-2020, 12:49 AM | #11 |
I've seen the wheelbarrow firewall before. I actually picked up a Radio Flyer wagon with the same thought process. Since I did my MII install, everything changed, so I need to go up and back. LOW AD's firewall is exactly what I need. Back to the drawing board, I guess.
04-12-2020, 04:06 PM | #12 |
My buddy used a wheelbarrow in his Model A roadster and it worked pretty good. Used to be you could find a new metal garden wheelbarrow for about 20 bucks this time of year new but most are plastic now.
LS Fab makes some nice bead rolled firewalls For AD trucks but don't show any recesses. https://lsfab.ca/product-category/4754/ One would have to ask about the size of the opening around the engine though.
04-12-2020, 07:27 PM | #13 |
Firewall for a 4" setback- made on a HF bead roller
Initial fitting with lots of clecos From the inside of the cab- |
04-13-2020, 03:37 AM | #14 |
I used wide-jaw vice grips and those big triangular welding magnets.
1951 Chevy Panel Truck |
