Old 05-17-2020, 09:06 AM   #1
msgtmac
Front Discs on the old control arms
Has anyone ever converted to disc using the stock control arms? I am thinking about doing the switch and really don't want to change out the cross member or the arms. Can I do ball joints and spindle? Also want to do the brakes without a booster to maintain engine bay look. I am doing a master cylinder swap to a 2 chamber. All help is appreciated.
msgtmac is offline   Reply With Quote
Old 05-17-2020, 09:41 AM   #2
AcampoDave
AcampoDave's Avatar
Re: Front Discs on the old control arms
Sure, many of the usual vendors ( Cpp, Brothers, Lmc, etc) sell disc brake conversion kits that don't require you to change the arms. As for the booster....I don't use one and the pedal effort is about the same as stock brakes.
AcampoDave is offline   Reply With Quote
Old 05-17-2020, 12:21 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Yes, on my 63, I used a PerformanceOnline kit back in 2015. I believe that the spindles they used were new squarebody style spindles, so the kit came with the correct ball joints for the spindles. The ball joints fit my stock arms with no issues
Included in the kit was a dual master with proportioning valve. I have been running my truck without a brake booster since I installed the kit. It stops well and I haven't had any issues with it
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 05-17-2020, 07:53 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.67-72chevytrucks.com/vboa...isc+brake+swap
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-18-2020, 06:22 PM   #5
demian5
demian5's Avatar
If you have a 60-62, do yourself a favor and convert to a 73 up front cross member and suspension.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-22-2020, 04:06 PM   #6
forestb
forestb's Avatar
what year truck? If you have a torsion bar front end and are not planning on lowering it any more than 5 inches or installing bags I would suggest not changing the cross member. I did and it was not at all worth the work. Sorry to disagree with you demian5.
forestb is offline   Reply With Quote
Old 05-27-2020, 10:26 AM   #7
19GMC66
19GMC66's Avatar
Pick your spindle 71-72 or 73-87 then use ball joints for that spindle and you have to use a tie rod adapter so that you can use adapt your year truck tie rod with the spindle tie rod. I did this on my 66 burb and used 86 square body spindles because they were free to me. I just can’t remember the tie rod combination outers or inners used with the adapter but there are write ups on the subject. Easy install to do.
19GMC66 is offline   Reply With Quote
Old 05-27-2020, 10:10 PM   #8
Chevy Fleetside
Late model outers used as outers and early outers used as inners.
Old 05-27-2020, 10:18 PM   #9
19GMC66
19GMC66's Avatar
There ya go! Thanks couldn’t remember the combo
Old 05-27-2020, 10:23 PM   #10
AcampoDave
AcampoDave's Avatar
If I recall correctly torsion bar trucks have an entirely different lower ball joint than the coil spring trucks, and they don't interchange into the A arms.
Old 05-27-2020, 10:36 PM   #11
forestb
forestb's Avatar
Do we know what year it is?
Old 05-27-2020, 11:01 PM   #12
slepysal
slepysal's Avatar
I swapped out my drums on my 60 to disc about 5 years ago using drop spindles and local parts house parts. I kept the torsion bar suspension and have had no issues . Here is my link but tinny pics photos no longer show up. Farily easy one mandriveway weekend job
http://67-72chevytrucks.com/vboard/s...ight=1960+disc
as mentioned We need to know what year your working on
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-28-2020, 11:15 AM   #13
verdell
verdell's Avatar
Went the same route on my 1960 back in 2004 with no issues. Added rear discs last year as well.
verdell is offline   Reply With Quote
