Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-31-2018, 10:31 AM   #1
OregonNed
OregonNed's Avatar
Headlight relay upgrade question
Guys, I would like to upgrade my stock wiring set-up for Headlight Relays, but not sure what kit to choose. I have sealed beams right now, ('68 C-10), and would like to install relays before I decide to upgrade lights, (if needed afterwards - I hear this change alone can improve brightness performance). Would really appreciate advice on what you may have used, and that you liked. Thanks in advance, Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-01-2018, 05:42 PM   #2
crossfire84
crossfire84's Avatar
Re: Headlight relay upgrade question
try this.www.classicparts.com
I have this on my 50
search under headlights
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 09-01-2018, 09:39 PM   #3
lutronjim
I got the same type setup from LMC. One of the relays went in a matter of days. I bought replacement relays from Summit and its been OK for a couple of years. I also got the lens gear for lamps to replace seal beams - major improvement.
Because of a LS conversion I reversed the intended direction and moved the relays to the driver's side. I took the harness cover off and ran the wires through the original side to side wire 'loom'.
lutronjim is offline   Reply With Quote
Old 09-01-2018, 10:51 PM   #4
OregonNed
OregonNed's Avatar
Thanks for the advice. I did order the LMC harness with 2 extra relays to have on hand.
Old 09-03-2018, 09:33 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Headlight relay upgrade question
I made mine for less than $10.00.
I rewire golf carts all the time so the wiring wasn't a problem.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-02-2018, 04:51 PM   #6
tdangle
tdangle's Avatar
I'm doing mine this weekend. I have about $15 in mine since I needed to buy some wire and replaced the sockets to the headlights. Any tips Andy?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 10-04-2018, 11:33 AM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Headlight relay upgrade question
It's a pretty easy upgrade really.
Take a test light and pull the head light connector off the drivers side light.
With the test light on one of the contacts figure which wires are which...High/low.
The drivers side connector works both lights.
Then cut them about 12" away form the light.
Take the end from the harness and this will be your trigger wire for the relay # 86 in the picture to the H beam one you are doing. Then the end to the head light goes to #87.
You can run a #10 are #8 wire from the battery for the hot wire to the relays # 30 on both with inline fuse.
Then ground each relay #85 to a good ground close to the relay.
Repeat this for both relays.
Old 10-05-2018, 08:40 PM   #8
Longhornss
Put a set of H4 LED's in it instead of Halogen upgrades.
They are WAY brighter and do not require a Relay upgrade.
Longhornss is offline   Reply With Quote
Old 10-07-2018, 11:23 AM   #9
tdangle
tdangle's Avatar
Just finished my relay upgrade. Less than $15 since I already had the wire. New relays and headlight sockets. Now have 14 volts at the lights. Haven’t had a chance to drive after dark yet but they appear much brighter.
Terry
Old 10-09-2018, 11:28 AM   #10
Andy4639
Old member
Andy4639's Avatar
Now with the new brightness make sure you aim them good to get full benefit of them.
Old 07-19-2019, 12:33 AM   #11
Livemeyer
Livemeyer's Avatar
My new headlights with halogen bulbs passenger side burned out first time I drove at night (sheesh!). I'm doing what you suggest, I have ordered LED replacements. I figure with lower wattage I can avoid installing relays and LEDs shouldn't destroy themselves first time I drive my truck at night.
Livemeyer is offline   Reply With Quote
Old 08-14-2019, 08:49 PM   #12
firedemon
the relay upgrade isn't just about brighter lights . it takes a significant load off the mile and a half undersize wiring and headlight switch when going with modern lighting . if you take a voltage reading with a good meter you will see sometimes 10 volts or less depending on condition and age . the original lights would light no problem be it a little dull but those modern lights including those led like the full 12-14.5 if you want that life expectancy and brightness your looking for . if your buying a harness from lmc or any other you might want to upgrade to some good bosh 30 or 40 amp relays they will last much longer than the ones that they buy for super cheap and put in to keep cost down . even if your not doing a light upgrade its a worthwhile mod to take the stress off that 50 year old wire all the connectors and headlight switch . and dont forget to make sure those grounds are in great shape
firedemon is offline   Reply With Quote
