Old 08-16-2015, 10:15 AM   #126
88fordf150
88fordf150's Avatar
Re: Project 69 Blown Gasser!
Frame was covered in dust. Pushed it outside to power wash it off.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 09-09-2015, 08:04 PM   #127
88fordf150
88fordf150's Avatar
Painted the bottom of the cab and mounted it on the frame for the last time! Paint is Inferno Red Metallic with 3 coats of clear ( camera makes it look more orange than dark red). I'm super happy how it turned out.
Brad handshoe
Old 09-09-2015, 08:08 PM   #128
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is that a dodge color?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-09-2015, 08:48 PM   #129
88fordf150
88fordf150's Avatar
Kirker Paint, not sure if its the same as Dodge?
Brad handshoe
Old 09-10-2015, 09:01 PM   #130
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That turned out awesome!
Ryan
1969 Chevy milk truck
Old 09-13-2015, 12:36 PM   #131
88fordf150
88fordf150's Avatar
Thanks!
Brad handshoe
Old 09-14-2015, 12:13 AM   #132
tommys72
tommys72's Avatar
Looks good, I'd drive it!
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 10-17-2015, 07:58 AM   #133
88fordf150
88fordf150's Avatar
Finally painted the rest of the cab, except for the top, painting the top white and then clear with pearl.
Brad handshoe
Old 10-18-2015, 08:20 PM   #134
jjzepplin
jjzepplin's Avatar
You are one good painter sir!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-18-2015, 08:43 PM   #135
68Gold/white
LOL, X2 on that!!! I've seen reflections in paint, but never from the bottom of the cab floor!!!
68Gold/white is offline   Reply With Quote
Old 12-13-2015, 06:23 PM   #136
88fordf150
88fordf150's Avatar
Disassemble of my doors for sand blasting and skins.
Brad handshoe
Old 12-13-2015, 11:00 PM   #137
Possmguts
Possmguts's Avatar
This thing is gonna be so awesome.. Im tuned in foe the doors.. About to do mine.. please tell all you can and what brand of skins and bottoms you use. I desperately need the drivers side hinge area... I see you need some work around yours too.. what do you plan on doing there?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 01-24-2016, 06:38 PM   #138
88fordf150
88fordf150's Avatar
Installed the steering column and moved it forward about 3" to give the driver a little more room. Also did a little work on the headers to get them to clear the steering shaft and welded up some 3" exhaust pipe to feed the Jones Chambered Mufflers. Oh, and changed the throttle linkage over to a cable pedal.
Brad handshoe
Old 06-04-2016, 02:42 PM   #139
88fordf150
88fordf150's Avatar
It's been a long time since I updated this. Today I painted the top Pure White and epoxy primed some other parts. You may notice I installed a brake booster & master along with gauges and header wrap. Getting close to starting this thing up!
Brad handshoe
Old 06-04-2016, 06:10 PM   #140
cericd
cericd's Avatar
Lookin' good. I really dig this project.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 11-13-2016, 10:10 AM   #141
88fordf150
88fordf150's Avatar
A few more pictures of my progress.
Brad handshoe
Old 12-05-2016, 01:15 AM   #142
grass
grass's Avatar
So glad I found this build, I've been tossing the idea of doing a gasser build with my 68, but hadn't seen anyone try it yet. I love it and I think you just sold me on the idea.
Chevy Pride
grass is offline   Reply With Quote
Old 12-05-2016, 05:03 PM   #143
88fordf150
88fordf150's Avatar
Glad you like it. I tossed around the idea of going with a straight axle front but didn't.
Brad handshoe
Old 12-05-2016, 05:08 PM   #144
grass
grass's Avatar
I have both a factory ifs front end and a straight axle out of a mid 40s Chevy truck. My truck was originally a 4x4 K20 so the straight axle will be pretty easy to do and I believe that is the route I'm heading in, but I'm sure the ifs would be a lot nicer to drive.
Chevy Pride
Old 12-12-2016, 01:03 AM   #145
swamp rat
swamp rat's Avatar
Door progress?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-12-2016, 05:53 AM   #146
88fordf150
88fordf150's Avatar
Originally Posted by swamp rat View Post
Door progress?
Doors are on hold until spring, going in for Hernia surgery next week.
Brad handshoe
Old 06-17-2017, 07:14 PM   #147
88fordf150
88fordf150's Avatar
Cut the door bottoms and had them sand blasted. Plan to spray some epoxy primer in the next few days.
Brad handshoe
Old 06-19-2017, 03:27 PM   #148
Dieselwrencher
Nice work! I hope all went well with your surgery earlier this spring.
Ryan
Old 06-19-2017, 04:37 PM   #149
Threerun
That paint is gorgeous!
Threerun is offline   Reply With Quote
Old 10-15-2017, 09:19 AM   #150
88fordf150
88fordf150's Avatar
Getting a little closer to being done. Covered the inside door panels with copies from old drag racing magazines to match the headliner.
Brad handshoe
