05-09-2020, 05:05 PM | #1 |
Trans Cable Shifter Linkage
I picked up a Lokar cable shifter assembly 1804 for my truck. Finally got it installed and for the life of me could not get it to shift to all the gears. Had to remove it and go back to the rod style assembly which works great.
My reason for going to the cable as to eliminate the vibration in the column shift lever due to the idle quality of my motor. Figured the cable system would eliminate all vibration and movement when you accelerate. Has anyone got this working?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-10-2020, 09:16 PM | #2 |
Roto Reuter thats the name...
Re: Trans Cable Shifter Linkage
I considered the cable mounted shifter, but went with the Lokar ACA-1800 rod style. I've heard that the cable shifter wasn't as good as the hard rod style, but I don't have the experience to confirm that. I'm still trying to get mine dialed in on my 5.3L/4L60E swap. I can't get the rod style to shift in all gears. Seems like a lot of variables that can be adjusted like the clocking of the arm on the transmission, where to lock down the heim joint on the arm and position of the arm on the column. I guess I'll have to just keep trying different things. Good luck with yours.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-11-2020, 03:33 PM | #3 | |
05-11-2020, 04:58 PM | #4 |
Thanks for the help. I'll keep working on it. I'll let you know how I make out.
05-12-2020, 12:16 PM | #5 |
No prob. I have mine working perfect with my 2004r 4 speed auto. I just was trying to get rid of the idle vibration in the shift lever. Guess I'll live with it.
