08-23-2019, 11:14 AM | #1 |
New brake booster size ?
I have a 72 C10 swb with disc/drum set up. I hate the current brake pedal. Seems I have to stand on it to get adequate brakes. I was looking at upgrading to a dual diaphram booster design. Would 7" or 8" be better? Any suggestions from anyone who has done this upgrade...? I was looking at a company called LEED Brakes. There pricing seems good and have great reviews. Anyone heard of them? Heres a link to the setup i was looking at. Thanks.
https://leedbrakes.com/i-23439481-co...ve-chrome.html Last edited by Syclone3Mt; 08-23-2019 at 03:26 PM. |
08-23-2019, 12:51 PM | #2 |
Old member
Re: New brake booster size ?
Go with the stock booster 11" and you will be much happier! I tried a 8" and hated it. I went back stock.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-23-2019, 12:56 PM | #3 |
Was the 8" booster too touchy?
08-23-2019, 01:44 PM | #4 |
I have seen Andy post about liking the 11 inch stock better but can't remember why exactly.
I have this set on one truck: https://www.ebay.com/itm/1967-1972-C...m/330948170372 I like it so much I ordered another for my other truck. |
08-23-2019, 02:20 PM | #5 |
I used a booster for a c30. Love it
08-23-2019, 02:38 PM | #6 |
Will a bigger brake booster provide more power assist for the brakes so a person doesnt have to apply as much brake pedal pressure?
08-23-2019, 03:18 PM | #7 |
Old member
No , it just didn't seem to work as good as the original 11".
I had the stock booster in my 71 and thought the 8" chrome booster would be a little nicer to the eye under the hood. I never liked the way it stopped compared to the 11" for 30 some years. It may have been just me but i went back to the 11" after a year of hating the way it worked.
08-23-2019, 03:28 PM | #8 | |
08-23-2019, 04:16 PM | #9 |
Thanks for the advice.
08-23-2019, 04:39 PM | #10 | |
08-23-2019, 05:13 PM | #11 |
Vacuum is good, put in a Texas Speed Low Lift 212/218, .550/.550 cam. Idles real nice with a slight lope. I think the current booster may have a diaphragm thats leaking or just old and worn. Just would like a softer pedal is all. So many choices out there for brake parts.
08-23-2019, 07:58 PM | #12 | |
My 454 BBC develops only 15 - 16 inches of vacuum at idle.. The lopey cam won't allow the engine to idle much below 1,000 - 1,100 RPM, and the stall speed of the torque convertor matches the cam's requirements and specs.... Even through all this, the brake pedal pressure and overall stopping power is just fine.. I guess all that bling - bling on that $360.00 master cylinder/booster suits some people, but I installed this $170.00 unit on my truck.. https://www.summitracing.com/parts/sum-760197/overview/ |
08-23-2019, 09:34 PM | #13 | |
Posted via Mobile Device |
08-24-2019, 06:11 PM | #14 | |
I like the looks and idea of that kit. When you buy a kit like that, is there way to go into a car parts store and tell them a make/model/year and get a replacement master cylinder across the counter to replace the one in that kit? Or way to get a replacement booster? Or is it necessary to buy a new kit every time a part of it wears out or breaks and needs replaced? |
08-24-2019, 09:30 PM | #15 | |
08-30-2019, 01:00 PM | #16 |
Well I decided to go with the ebay purchase and get the 8" dual diaphram booster with new proportioning valve. Bled the brakes and took it for a cruise last night. What a difference in braking performance. I measured vacuum to booster. In park idling, vacuum is 15.8" W.C. In gear idling its 18.2" W.C. The brake pedal is so much better, way more assist. Now to replacing the rear drums, shoes and wheel cylinders this weekend!
08-31-2019, 02:23 AM | #17 |
Active Member
It doesn’t seem popular but I looked at getting a dual diaphragm 9” booster. They come from 70s vettes I think. More power than a single 11” but not as wide. Less power than the big c30 dual 11”. Ultimately I went with the single 11” because it was the easiest and I have the vacuum.
https://www.jegs.com/i/Tuff+Stuff/90...xoCIDIQAvD_BwE
David Larsen 1970 Chevrolet C-10 |
08-31-2019, 11:32 PM | #18 | |
08-31-2019, 11:35 PM | #19 | |
09-03-2019, 06:05 PM | #20 |
Thanks Rusty, still waiting on parts for rear brakes.
01-14-2023, 12:28 AM | #21 | |
