Old 08-19-2019, 09:29 PM   #1
wshattuck
wshattuck's Avatar
new RnD radiator installed...
well after a few months i finally got the new RnD radiator i got installed. took me an hour going through all the hoses at the auto parts store to find the right ones for my LS swap. i am listing the hose part numbers below in case it could help someone else. i think it looks pretty good in there and it fits like it should... i do like the inlet and outlet on the same side.
Continental #62143 upper
Continental #61416 lower
will
1969 C10, ZZ502, T400, A/C, WoodBed, Bucket Seats
1965 C10, 5.3LS, 4L60, Vintage Air, Woodbed
wshattuck is offline   Reply With Quote
Old 08-19-2019, 10:02 PM   #2
roll_the_dice
roll_the_dice's Avatar
Re: new RnD radiator installed...
Looks great! I have an RND radiator also and should be installing it in the next few weeks.
roll_the_dice is offline   Reply With Quote
Old 08-20-2019, 09:17 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Nice!
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-20-2019, 06:28 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Any mount adjusting?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-20-2019, 07:44 PM   #5
wshattuck
wshattuck's Avatar
no mounting adjustment needed for my truck... i had to buy the correct upper and lower mounts and pads from LMC since the ones that were in there were not anywhere close to the right ones...
Old 08-21-2019, 10:22 AM   #6
Clyde65
Clyde65's Avatar
Great! Thanks!
Clyde65
Rebuild of Clyde
support our troops!
Old 08-21-2019, 02:38 PM   #7
Duncan K
Looks great, thanks for sharing the part numbers for the hoses. My RnD radiator is lost in UPS land, no one can seem to find it.
What air intake is that? I need to order one
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 08-21-2019, 03:29 PM   #8
wshattuck
wshattuck's Avatar
sceptre air intake... i like the tube and bends but the air filter seems to flex alot... i have ordered a new one to replace it.
will
Old 08-21-2019, 06:27 PM   #9
wshattuck
wshattuck's Avatar
here is an updated pic with the new filter installed... much cleaner looking i think.
Old 07-22-2020, 07:45 PM   #10
roll_the_dice
Bringing this back up ...I am installing my RND radiator soon and just realized my bracket is not the right one. You bought a new bracket from LMC top and bottom?
Old 07-22-2020, 08:39 PM   #11
wshattuck
wshattuck's Avatar
yes i sure did... fit like a champ!
Old 07-22-2020, 09:12 PM   #12
roll_the_dice
Awesome...thanks! Much appreciated!
Old 09-01-2020, 03:09 PM   #13
Pitpig
Did you have to use a reducer for the upper hose?
Pitpig is offline   Reply With Quote
