09-01-2014, 02:56 AM | #1 |
327 fan setup
Working on my '66 custom camper with original 327 - does anyone know what kind cooling fan came on this engine from the factory? Did they come with a fan clutch? I have one of those fans with the flex blades and I am sure this was not the original configuration. I'm trying to take the setup back to the way it came from the factory. thanks - Rob
66 Custom Camper 327 AC PS PB 66 C20 292 76 C25 Sierra Classic 76 C25 Sierra Grande 76 Camper Special 77 Sierra Grande 02 Suburban - the DD |
09-01-2014, 03:09 AM | #2 |
Re: 327 fan setup
Here's a pic of my '65 with a 283. It's a 4 blade. Should be the same as a 327.
09-01-2014, 03:15 AM | #3 |
Re: 327 fan setup
Thank BBob... so do you run with a fan shroud or just as shown in the pic?
09-01-2014, 03:37 AM | #4 | |
Re: 327 fan setup
I switched to a 4 row radiator and 7 blade fan with clutch. I also picked up an original shroud and mounting brackets that I have yet to install. The 7 blade does a good job though, even in the Phoenix heat. If you can't find one locally, I've still got the 4 blade. Should be cheap and easy to find at a scrap yard though. |
09-01-2014, 03:47 AM | #5 |
Re: 327 fan setup
Thanks for the very helpful info. I will look for the fan and shroud at the local scrap yard. --Rob
09-01-2014, 09:21 AM | #6 |
Re: 327 fan setup
they would run a 4 blade and 5 blade . you could also get a clutch fan setup with 5 blade . they all used the shroud .
09-01-2014, 10:37 AM | #7 |
Re: 327 fan setup
BBob, which clutch fan did you buy if you don't mind. Did it have a themostat? Where'd you get it? Also does a 4 row fit in the stock brackets? Thanks
09-01-2014, 11:46 AM | #8 |
Re: 327 fan setup
4 row has different brackets up and down and the pads are different from the others. the tanks on the 4 row are 3.5" the others are 3.0"
09-01-2014, 11:54 AM | #9 |
Chevy addict
Re: 327 fan setup
My 1965 C30 camper/motorhome has a 5 blade fan with clutch and schroud
09-01-2014, 02:24 PM | #10 |
Re: 327 fan setup
I have no idea what clutch it is, I bought it used. It's actually a Champion 3 row (CC284). Had to look it up, it's been a while. I like the look of the old radiators, but the price was right, so aluminum it is! It fit perfectly in the saddles, but I had to get a new top hose because the old connection was in the center, and the new was on drivers side. For anyone with the same challenge, I got the hose from O'Reilly's part number 20607.
09-01-2014, 02:43 PM | #11 | |
Re: 327 fan setup
09-01-2014, 02:53 PM | #12 | |
Re: 327 fan setup
I got the radiator on ebay. You can get a 7 blade fan at any parts store. I do like that the clutch gets the fan a little closer to the radiator. Here's a little eye candy for ya. |
09-01-2014, 10:40 PM | #13 |
Re: 327 fan setup
I'll defer to Yelmer on this but I think the determining factor on the fan configuration was the transmission on your Custom Camper. The TH400 auto got the bigger, 4 row radiator. Not sure if the stick did or not. Mine has the TH400, as does Yelmer's, with a shroud. My fan is 6 bladed.
Check out our little Custom Camper club here: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
09-02-2014, 02:24 AM | #14 |
60-66 Nut
Re: 327 fan setup
The OP's truck also has AC which I think would require a better fan than typical. I'm not sure if it would have been a clutch fan, but highly possible.
09-02-2014, 03:53 AM | #15 |
Re: 327 fan setup
So is the 7-blade fan with a thermal clutch the ultimate solution for the best cooling (with A/C)? Although I understand how it works mechanically, guess I am not totally sure how the fan clutch affects the cooling. When the clutch heats up, the fan turns slower, right? So is the idea that too much airflow is a bad thing? I really want to thank everyone to some great replies to my post. PS: BBob, that's a good looking engine - is that in your ride now?
09-02-2014, 10:21 PM | #16 |
Re: 327 fan setup
I didn't know clutch fans were available on 66 pickups. I've been wrong before but I thought they were a later development, no?
09-02-2014, 10:36 PM | #17 |
Re: 327 fan setup
Here is a very oil untouched 65 c20 327 that had a 5 blade fan with a clutch. Here are before and after photos, havent put the fan back on yet.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ Last edited by Budman56; 09-02-2014 at 10:42 PM. |
09-02-2014, 11:35 PM | #18 | |
Re: 327 fan setup
The standard HD fan was a fixed 5 blade no clutch. This fan is shown in the 64-66 factory Air Conditioning instruction manual. Heres a picture on a factory air 1966 292 .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
09-02-2014, 11:55 PM | #19 |
Re: 327 fan setup
The oct 67 chevrolet parts book lists 65 -66 series 10-30 c.a.c. H.d. Radiator 327 part 3883159 fan blade 2nd design also the clutch for the blade is part 3883158 serie 10 -30 w a.c. H.d rad 327 2nd design
09-02-2014, 11:56 PM | #20 |
Re: 327 fan setup
09-03-2014, 12:03 AM | #21 |
Re: 327 fan setup
The clutch
09-03-2014, 12:06 AM | #22 |
Re: 327 fan setup
Sorry Winston but this is one of the trucks I need that shroud for. 1966 short fleetside 292 Ac truck
09-03-2014, 12:07 AM | #23 |
Re: 327 fan setup
09-03-2014, 12:17 AM | #24 |
Re: 327 fan setup
I will need to take a picture will post later
09-03-2014, 12:19 AM | #25 |
Re: 327 fan setup
i got this one from a guy claiming correct for L6 with ac
