11-06-2020, 11:08 PM | #1 |
17" Wheel Backspacing
1971 4WD Blazer, stock height
Will 4.5" backspacing work on a 17" rim. Is the outer tie rod still able to hit the 17"? I'm thinking of putting these wheels on to test clearances before ordering some custom forged wheels. https://www.ebay.com.au/itm/1-Vision...h/193301524863 |
11-07-2020, 03:49 PM | #2 |
Re: 17" Wheel Backspacing
I run 17x9 with -12mm offset (4.5" backspacing) and it clears fine.
11-07-2020, 05:05 PM | #3 |
thanks, would you happen to have pics?
11-07-2020, 08:06 PM | #4 |
11-07-2020, 09:04 PM | #5 |
Thanks, I did find your build thread, nice job. If you can grab a pic of tie rod clearance, I won't have mine for at least 6 weeks.I want to order rims so they can travel with truck to Australia
11-07-2020, 09:14 PM | #6 |
I was outside tinkering anyways so i got you some pics.
17x9 4.5" backspacing (-12mm offset), 37x12.50r17 Goodyear MTRs. I think they fit well. |
11-07-2020, 10:17 PM | #7 |
Thanks, looks like lots clearance with 17". My current plan is stock height with a 31" tire. But good to know if I decide to lift will have plenty of tire space.
11-07-2020, 11:41 PM | #8 |
Tons of clearance, yes. You ought to be able to fit a 33" at stock height. lots of other posts on lift vs tire size if you need that info.
