Old 03-12-2013, 12:26 AM   #1
1979bonanza
Truck dies when hit gas to hard
All right guys i would value some advice again! My 79 bonanza is driveable now and is my DD to and from school and work, a problem im having is when i get on it to hard (halfway to floor) it sputters and dies and makes me look like an idiot, im running stock exaust out of a 350 with rebuilt tranny any ideas on how to stop the sputtering?? im thinking carb issues.
1979bonanza is offline   Reply With Quote
Old 03-12-2013, 09:11 AM   #2
Lee H
Lee H's Avatar
Re: Truck dies when hit gas to hard
Welcome to the board. What kind of carb are you running and when did this start? If your running a quadra jet, it's the accelerator pump.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 03-12-2013, 10:14 AM   #3
hotstuff
Other causes sticking metering rods , vacuum leak, floats to low , lack of fuel .I agree with Lee H accelerator pump .remove air cleaner rack the linkage and you should see a strong squirt of fuel.
hotstuff is offline   Reply With Quote
Old 03-12-2013, 12:07 PM   #4
1979bonanza
Thanks guys! Ill look into the carb and find out if anything you mentioned is wrong with it.
Old 03-12-2013, 12:15 PM   #5
SSC's76
No No
SSC's76's Avatar
if its a qjet the secondary air valve is set wrong. check the tension on the air flap. with the choke off press down on it if it takes alot of pressure to open then its way to tight if it flops open then its to loose. you want just enough where it will open with little effort but springs back.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
