11-11-2020, 05:29 AM | #1 |
solenoids
hey guys
i have shaved doors on my 57 and i want to do the solenoid thing . i have heard the old school way of using gm starter solenoids . has anyone gone this route? i understand there are pretty good companies that make complete systems with there own solenoids---dont need that i just need 2 good strong ones. I have the bear latches- and my doors are tough to release the latch - any suggestions would be great Dont know if there is a different wiring set up for the GM"s just looking for good strong solenoids . Diagram would be nice too daze57 |
11-11-2020, 09:02 AM | #2 |
Moderator
Re: solenoids
Yes many years ago. Sounds like your latches aren't aligned properly though. Bear Claws are usually very smooth. I have them on my 64 and it's they are feather light to open. Only one finger to close the doors.
11-11-2020, 12:08 PM | #3 |
Old member
Re: solenoids
Most solenoids are tough depending on how they are used. Typical wiring is the same for all of them. Solenoids are 2 systems in one unit. Activation side and the power side are the side that does the work. Activation side is the 2 small terminals. These 2 small studs activate the solenoid to pull the coil in so the 2 bigger studs can send power to something that requires a lot of amps.
Here is a quick drawing I did in paint. I'm not artist so bare with me. The solenoid for a car is typically 12 volt DC activation and less than a 100amps. most times. Depending on the popper rating you have you will need to get one as close to it as possible, preferably a little more than it's rating. This link is for a 12 v DC 100amp solenoid Continuous. Hope it helps you out. https://www.grainger.com/category/el...&filters=attrs
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 11-14-2020 at 01:45 PM. |
11-13-2020, 05:42 AM | #4 |
Re: solenoids
thank you guys very very much ---good information
