Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-17-2020, 03:38 AM   #1
Greasey Harley
Greasey Harley's Avatar
Idle too low low to charge
I recently did some upgrades to the ol truck and ended up draining the battery while testing all the systems. Then I warmed it up and took a screwdriver to the 2jet. got it idling real good, nice and smooth, about 550 rpms, sweet... Not so much.
At 550rip'ems the alternator puts out 11.50 volts with the radio on low and the heater on. With a minimal charge on the battery and a 10 minute warm up this morning the battery was at a deficet. Drove 4 miles to work ( not enough to charge) and my battery was dead after work. Good thing I parked on a hill. Anyways, after a little head scratching, I think I have it figured out. --->I tuned the carb too dang good. I readjusted the Idle up around 650rpm, the alternator stabilized at 13.2v with the radio on and the heater on high, 13.1v if the park lights are on too. Bummer, the thing sounded sweet at a 550 rpm.
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 11-17-2020, 11:07 AM   #2
skip99
skip99's Avatar
Re: Idle too low low to charge
Change pulleys
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 11-17-2020, 07:22 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Idle too low low to charge
Did you check the belts and tension on the alternator belt.
It could be slipping are just not tight enough.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-17-2020, 08:30 PM   #4
Dead Parrot
Which alternator do you have? A 12SI has about 7 more amps at engine idle speeds then the older 10SI.
Dead Parrot is offline   Reply With Quote
Old 11-17-2020, 10:04 PM   #5
Greasey Harley
Originally Posted by skip99 View Post
Change pulleys
Stock pulleys seem fine, It didn't cost anything to bump the idle up a few rpm.
It might be a tiny bit loose, the belt chirps at high rpm, it wasn't slipping at idle though
It's a 10DN, still rockin' the regulator on the core support.
The truck seems great now, drove it all day. no problems.
Old 11-18-2020, 12:42 PM   #6
Andy4639
Old member
Andy4639's Avatar
Remember a alternator is not meant to charge up a dead battery. That is the worst thing you can do with it. If your battery is dead charge it with a charger. I know if your stranded you can't but I'm talking about when you do it at home. Put it on the charger. Let it fully charge before you test it. If it wasn't fully charged when you tested the battery out then that's why.
From your response you have a straight drive so the RPM @ idle is a little lower than a auto. Don't know for sure what model you have but a 67-72 C-10 straight drive stock motor is about 650-700 @ idle. If you have a different cam then it would be something else. When warm.
Old 11-18-2020, 02:41 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The newer CS alternators output more amps at idle to make those headlights brighter and charge the battery better. Just saying.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-26-2020, 03:38 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
R&R the EVR. It's getting hard to get a good one anymore.
Still using it on my '68 C/10 w/292. My Checker Auto lifetime warranty gets me a low quality replacement from O'Reilly's. This one charges now, but I get the RED GENERATOR light on the dash when I pull the key out. For now, a good thunp on the left front fender [below the reflector] shocks the body enough to free the sticking contact inside the regulator.
On my '71 GMC Jimmy, w/350 I got a new-built 12SI [for a " '76 GMC"] alternator, and connected some wires before the EVR connection. [F + 3, 1 + 2]. Different inputs to the back of the Alternator, and now it works great.
'68OrangeSunshine is online now   Reply With Quote
