Old 08-19-2020, 08:32 AM   #1
Juan
1966 tailgate handle
i wanted to come up with a handle that was clean and flat as possible, so i came up with this set up, no visible bolts or screws holding this from the front or back
Juan is offline   Reply With Quote
Old 08-19-2020, 08:35 AM   #2
Juan
Re: 1966 tailgate handle
More pictures
Old 08-19-2020, 08:36 AM   #3
Juan
Cant figure out how to fix the pictures
Old 08-19-2020, 03:06 PM   #4
TxCajun
TxCajun's Avatar
Looks good.
What handle did you start with?
Any detail pictures of the panel cut out and install?
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 08-19-2020, 05:37 PM   #5
Juan
89-98 chevy tailgate handle, i took a stock handle and cut roughly 3/4-1 inch out to decrease the height to make it more compact and cut away other material that was in the way, then i made a braket with some strong sheet metal that i had laying around, made some tabs to hold the handle assembly on the inside, and welded a thin nut so one srew bolds it on the bottom so it can be easily removed, then welded that bracket to the inside of the tailgate
