Old 09-09-2006, 02:11 PM   #1
hogrocket
Junior Member
2 different sized lugs--frt and back
I just received some rims from VTBLAZER and as I went to take of the stock rims I realized the front lugs are 9/16" and the rears are 1/2". It's a 1970 K20 LB with factory disc up front. (disc option is listed on the glove box options list) Has anyone ever heard of this or has there been some kind of conversion done. It all appears to be stock. Thanks Matt
hogrocket is offline   Reply With Quote
Old 09-09-2006, 02:17 PM   #2
msgross
msgross's Avatar
Re: 2 different sized lugs--frt and back
you can buy new studs at autozone...
msgross is offline   Reply With Quote
Old 09-09-2006, 02:22 PM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
i wonder if your rear axle has been replaced with a 73+
trkklr77 is offline   Reply With Quote
Old 09-09-2006, 03:07 PM   #4
junkyardjohn
junkyardjohn's Avatar
THESE TRUCKS DIDN'T HAVE DISC.S UNTIL 1971. SOMEONE PROBABLY CHANGED IT TO A 73 ON UP FRONT CROSSMEMBER. I THINK ALL OF THE 3/4 & 1 TONS HAD 9/16 DIA STUDS. THEY PROBALY ADDED THIS OPTION TO THE GLOVEBOX OPTION STICKER. YOU CAN BUY BLANK ONES ON EBAY FOR $5.00 & TYPE IN ANY OPTION YOU WANT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-09-2006, 03:39 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Agreed, quick fix, and you probably could use them anyways
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-09-2006, 04:11 PM   #6
hogrocket
Junior Member
Thanks JUNKYARD---your right--I thought they were factory, but looking at the glove box option sticker again it does not say disc--just power booster option. Anyway--that's just one conversion less that I have to do. Thanks again everyone.--Matt
Old 09-09-2006, 09:03 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
starting in 71, they added disk (as stated above) but that is also when they went to the 9/16 studs. You coupl probably get the rear hubs and drums off a 71 - 72 rear and put them on your truck if it really bothers you.
Just getting studs won't help. you'll need to redrill and spline the hubs, and then redrill the drums too.
Old 09-10-2006, 12:24 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
Iirc, your lugs should be 9/16 all around. You can replace the rear studs, bit you need a hydraulic press and a drill. For most guys, it's easiest to take the hubs to a machine shop.
An easy fix is to buy some adapter lug nuts. I ran into the same situation when I went to put newer wheels on my 52. My tire shop had some nuts that worked.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-10-2006, 01:06 PM   #9
Longhorn Man
swapping over to later wheels on older hubs isn't an issue. The wheel is uhub excentric, so you don't need to worry about centering it, or supporting the weight, and the taper in the lug nut and on the holes on the wheel are the same angle.
