Old 05-18-2019, 10:04 PM   #1
fordguy40
Question Manual window regulator roller question
How free are these things supposed to be? They're not seized or flat spotted, but they definitely don't roll free, either. After some spray lithium grease, I can rotate them on their balls, but they still seem tight to me.
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 05-19-2019, 04:23 PM   #2
rickit
rickit's Avatar
Re: Manual window regulator roller question
mine were kinda stiff so I had a guy install two new ones last year that came from lmc , the new ones were way worse then what I had, my friend ended up breaking the handle off trying to roll it up few months back needless to say that guy installed them thru the old regulators away, im looking for a good set but haven't had any luck yet
rickit is offline   Reply With Quote
Old 05-19-2019, 04:39 PM   #3
fordguy40
My windows are also hard to roll up even with almost non-existent weatherstripping. Hoping it was just due to the dried up white grease and junk in the roller channels but the hard, old weatherstripping doesn't help I'm sure.
Thanks for the heads-up on the aftermarket regulators. Trying to keep the truck as OE as possible, even if it means using old and ugly, but better-made, parts.
Old 05-20-2019, 02:28 PM   #4
Pontiac1976
Pontiac1976's Avatar
They should be smooth rolling snug. Try cleaning with parts wash to clean use com pressure air or can of com pressure air blow dry re lube. They should be lubed 1 a year at least looked at see if need re-lubed. This includes the tracks too.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-22-2019, 02:55 PM   #5
Matt Man
Matt Man's Avatar
On my 81 the drivers side regulator was completely frozen up when I got it so I bought a aftermarket from LMC it would work fine with fresh grease for about a week then it would get really stiff. When it got cold out I was afraid to roll the window up because I was in fear of breaking the handle. I went to the junkyard and found one out of a suburban works great hot or cold.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-22-2019, 03:23 PM   #6
fordguy40
They're definitely more free now, but I'm going to throw the whole regulator in the parts washer this weekend to see what a soak in some diesel can do.
Old 05-23-2019, 12:57 PM   #7
dagnabbitt
dagnabbitt's Avatar
I've found that they are virtually impossible to repair and/or rehabilitate. After I worked on mine it basically exploded inside the door. Of course, I might just be incompetent, I am sure others have had more luck with them than me.
I ended up getting one at the junkyard for nearly free, it's a good option because you can test it before you remove it.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
