Old 11-18-2017, 12:23 PM   #1
Kowtown
Kowtown's Avatar
Throttle linkage hookup on Fitech ??
Looking for any info (pic please) on the hookup of Acc linkage on a Fitech setup for 67 C10 with 383 engine. I have a bracket from Jegs for the 700R4 TV cable but the bracket has a square hole for the acc cable and my acc linkage is a straight rod type.
Kowtown is offline   Reply With Quote
Old 11-18-2017, 12:27 PM   #2
mkmc69
mkmc69's Avatar
Re: Throttle linkage hookup on Fitech ??
Looks nice!! I'm going to assume, you are going to have to convert your rod style linkage to a cable style, to make this work. Check with Lokar. I think they have what you may need.
mkmc69 is offline   Reply With Quote
Old 11-18-2017, 07:29 PM   #3
Jrainman
Jrainman's Avatar
Ok all good on this one I have done this also new GM crate engine / 200 4r trans / installed fitech efi
This is what you need ( FAST EZ EFI Mount Kit part # 304-147 ) ,I ordered from Summit , if you look at the reveiws for this kit you will see others used for fitech install. a little on the high $ end as far as price but everything you need with O problems on install . I also have Rod style gas linkage / 200 4R and 700 R4 use same Detent cable and I will add cable is just where it should be for smooth operation .
Jrainman is offline   Reply With Quote
Old 11-18-2017, 07:37 PM   #4
Jrainman
Jrainman's Avatar
I dont know what kit you have, but the square hole is for your Detent cable it snaps in the square you want to install that squre bracket so the cable is level all the way through to your hook up on the fitech, it is not your gas/fuel linkage ,
Old 11-19-2017, 09:03 PM   #5
Kowtown
Kowtown's Avatar
So let me understand, did you stay with the rod linkage for fuel or did you convert over to a cable style for your fuel? If you have pictures I would appreciate it. Thank you
Old 11-19-2017, 09:33 PM   #6
mkmc69
mkmc69's Avatar
What did you use to paint your engine with?
Old 11-19-2017, 09:43 PM   #7
Kowtown
Kowtown's Avatar
House of Kolor Tangelo orange pearl.
Old 11-19-2017, 09:46 PM   #8
mkmc69
mkmc69's Avatar
Thanks. It looks nice.
Old 11-19-2017, 11:52 PM   #9
hotrod1967
Here’s what I did. Rebuilt new rod with parts from summit
hotrod1967 is offline   Reply With Quote
Old 11-20-2017, 12:03 AM   #10
hotrod1967
Old 11-20-2017, 01:41 AM   #11
dflarsen77
Active Member
Can't you just loosen the fuel pressure gauge fittings and point it up a little? Although converting to a cable throttle is safer.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 11-20-2017, 09:23 PM   #12
Kowtown
Kowtown's Avatar
Got the Acc linkage/TV cable adapter plate and TV cable bracket made today. Had to modify everything. Jegs #157301 &157310
Old 11-21-2017, 01:04 PM   #13
Big Kev-O
Big Kev-O's Avatar
Do Holley and Edlebrock carbs have the same throttle lever? FiTceh throttle levers have the same geometry as Holley. The Jegs 157301 is for Eddy carbs. I think you should have used a 157300 for 4150/4160 Holleys. Not sure you are going to get the correct geometry from the 157301.
I'm running the FiTech and could never get the linkage style pedal to open the throttle 100%. Installed the bowtie EZ-TV kit & a 72 cable style pedal. Problem solved.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 11-21-2017, 07:37 PM   #14
Kowtown
Kowtown's Avatar
Yes I think your right. After checking the throttle again it is not going 100% open. Do you have a good part number for the Bowtie EZ-TV kit? Did you use a Lokar pedal or something else?
Thanks. Darren
Old 11-21-2017, 07:54 PM   #15
Jrainman
Jrainman's Avatar
Yes I was able to keep the rod style linkage . looks good just make sure you pull (adjust) that detent cable all the way
Old 11-22-2017, 01:51 AM   #16
Rufas
Rufas's Avatar
Thanks. Darren
The Bowtie TV Made EZ system for the FiTech EFI is a modified Holley 4100 squarebore EZ system. Bowtie charges an additional $75 to modify that system. I had to send the FiTech TB to them for the modifications. Maybe things have changed since that was about two years ago. I checked the Bowtie site and there is not anything listed specific the the FiTech EFI. I suggest you call Bowtie Overdrives at 760-947-5240 to verify this info.
Bowtie Overdrive's TV Made Ez system - TVEZ4100 $149.95
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
