Old 02-02-2020, 10:06 AM   #1
Andyking1203
Suspension pros and cons...
I'm the proud new owner of a 1970 c10 longbed (gonna keep this for the time being) 2wd. The idea is to make a decent driver outta it with maybe a little bracket racing. It currently has a 6cyl 3 spd in it, that'll change to either a healthy small block or a 6.0 ls swap. My questions are. 1, nolimit 4 link or replace all the stock parts with tubular arms and lowering springs. 2 replace the front suspension with tubular a arms and lowering spindles. Thanks in advance
Andyking1203 is offline   Reply With Quote
Old 02-03-2020, 11:21 AM   #2
SCOTI
SCOTI's Avatar
Re: Suspension pros and cons...
What is your budget for each 'end' of the truck?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-03-2020, 05:22 PM   #3
Andyking1203
Budget isnt really a problem, gonna be a slow process reguardless.. obviously want bang for my buck!!!
Old 02-03-2020, 05:55 PM   #4
SCOTI
SCOTI's Avatar
There's nothing wrong w/original truck arms in the rear. If the truck has coils @ all 4 corners some simple parts can offer good ride quality & traction. If you desire change, No Limits 4-bar set-up is a great choice since it was mentioned.
If you're sticking w/the original front crossmember, Ridetech has a nice coil-over kit & Hotchkis makes a nice set-up designed to improve handling. If you're changing/ditching the crossmember up front for extreme changes, No Limit, Porterbuilt, Scotts, GSI, Choppin Block, Roadster Shop all offer updated parts that will work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-03-2020, 06:07 PM   #5
68Stepbed
68Stepbed's Avatar
The torque arm rear flat out HOOKS!!
https://totalcostinvolved.com/produc...evy-c10-truck/
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-03-2020, 06:12 PM   #6
Andyking1203
The front suspension will remain pretty much stock geometry, lower spindles, tubular a arms.. pretty much it. As for the cross member it can stay or go, obviously depending on the route I choose.. ivdont wanna c notch the Frame so itll be slightly lowered. I guess I'm looking for ride quality vs $$$
Old 02-23-2020, 09:15 AM   #7
Andyking1203
I'm curious, can anyone give me a specific idea of the rear gear ratio on a 1970, 6cyl 3spd manual base model truck.. thanks
Old 02-23-2020, 05:23 PM   #8
SCOTI
SCOTI's Avatar
Prob 3.73 's.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-24-2020, 09:23 AM   #9
68Stepbed
68Stepbed's Avatar
Prob 3.73 's.
Mine was originally a 250/3ott and had 3.73. Some trucks may have had 4.10, but like SCOTI said, 3.73 was more common. The only other option was 3.07, but that was mainly in the automatic trucks.
Matt
Old 02-27-2020, 07:41 PM   #10
Andyking1203
Thst would be great if it has 3.73 gears, truck is getting a 6.0 with a 4l80... decent combo?
Old 02-28-2020, 10:10 AM   #11
SCOTI
SCOTI's Avatar
Tire sizes play a roll but 3.73's/.75OD gearing is a common OE set-up. It will work well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-29-2020, 07:08 AM   #12
Andyking1203
As for tire/rim size. The only definite thing is, itll have 15" rally's on it. (They are free)!! Plus itll look "stockish". Also will be a fairly wide rear tire.
Old 02-29-2020, 08:52 AM   #13
SCOTI
SCOTI's Avatar
I was referring to actual tire size (OD) for calculations (engine cruise RPM's).15's thru 22's are only relevant to calculating the sidewall height for a given size which helps get a better idea on ride quality.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-29-2020, 08:50 PM   #14
Andyking1203
Not gonna put low profiles on it, I still want a decent wheel well filling tire.. not exactly sure yet..
Old 03-27-2020, 07:28 AM   #15
Andyking1203
So with a little research, I found out the truck is a 69, not a 70.. dont really think that matters.
For the time being, can I put a 71/71 ball joint in a 69 a arm? Also will the 71/72 tie rod work with the 69 drag link? Spindles will be for a 71/72.
Also thinking of lowering the truck with the 4" coils from lmc, do I need to replace the pan hard bar, or will stock be ok?
Old 03-27-2020, 10:32 AM   #16
SCOTI
SCOTI's Avatar
I found out the truck is a 69, not a 70.. dont really think that matters. No, it doesn't. The differences come into play in 71 (disc brakes changed things).
Can I put a 71/71 ball joint in a 69 a arm? Yes.
Will the 71/72 tie rod work with the 69 drag link? You need 71/72 outer tie rod ends for sure. You might need adapter sleeves if the inner/outer thread sizes are different or you can see if 71/72 inners work w/the current drag-link (I've had different results on different trucks as a result of things getting changed over the years).
Also thinking of lowering the truck with the 4" coils from lmc, do I need to replace the pan hard bar, or will stock be ok? The 4" drop coils will prob be ok but you'll be reaching the point of diminishing returns. There are aftermarket adjustable Panhard bars & you'll want one to allow centering the rear end because as it gets lower it will shift to one side. The aftermarket Panhard bars come in different lengths (long & short). The longer the bar, the less side-to-side shift there is when the suspension cycles up/down while driving.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-27-2020, 11:19 AM   #17
Andyking1203
Yes I'd use the 71/72 inner and outter tie rods
If I have to, or if it is suggested, I'd go to no limit... thanks scoti
Old 03-29-2020, 06:43 AM   #18
Andyking1203
Doing a 5 lug conversion, on the rear, will axle shafts out of a 94 1500 2wd fit in my 69?
Old 03-29-2020, 02:18 PM   #19
SCOTI
SCOTI's Avatar
No.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-29-2020, 03:13 PM   #20
Andyking1203
No.
Obviously to narrow?
Old 03-29-2020, 03:48 PM   #21
SCOTI
SCOTI's Avatar
The opposite. It's too long.
A 94 1500 (OBS) truck 10bolt is wider than 73-87 10bolt... which is wider than 65-70 12bolt rear end.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-30-2020, 09:33 PM   #22
68Stepbed
68Stepbed's Avatar
When I converted my 68 to 5-lug parts from a 72, I had to also reuse the drag link from the 72 because the 67-70 is different from the 71-72. It may be easier to just convert all of it to 72 parts so ordering replacement parts is simple enough.
Matt
Old 03-30-2020, 09:37 PM   #23
Andyking1203
I'm hopeing to find parts from a local junk yard, once the weather is good. Hopefully I can find what I want/need...
Old 03-31-2020, 09:39 AM   #24
SCOTI
SCOTI's Avatar
I've experienced this as well. Back in the day, I would snag center-links from 71/72's just for that reason. But adapters for tie-rod sleeves started eliminating that need. More than one way to get it done now which helps but adds confusion.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
