10-05-2020, 11:12 AM | #151 |
Re: Let's play name that part, bolt, harness, screw....
How about these?
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
10-05-2020, 12:09 PM | #152 |
Valve cover grommet for the flame arrester that comes from the air cleaner
10-05-2020, 02:45 PM | #153 |
10-05-2020, 04:34 PM | #154 |
10-05-2020, 10:53 PM | #155 |
Temperature related?
Lower Leaf spring U-bolt plates, window regulators & tracks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-05-2020, 10:56 PM | #156 |
E-brake cable grommets where it passes through the trailing arm cross member?
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
10-05-2020, 11:01 PM | #157 | |
I took the one remaining off my truck in 1997. Found a pair on EBay but can’t find what the part number is. Not easy to find them in the Chevy or GMC parts books. Last edited by John H.; 10-05-2020 at 11:16 PM. Reason: Added |
10-05-2020, 11:10 PM | #158 | ||
https://www.classicparts.com/1966-72...ctinfo/71-739/
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-05-2020 at 11:20 PM. |
10-05-2020, 11:24 PM | #159 |
Thanks! I have never really looked for them.
10-06-2020, 12:04 PM | #160 | |
The Older Generation
The '69 - '72 parking brake pedal bracket uses 3 of these 5/16" flange nuts. Two on the studs that hold the bracket to the firewall and one on the 5/16" bolt with small integral washer that attaches it to the bottom of the dash. I think the engine compartment heater box might use a couple of the 1/4 -20 flange nuts. LockDoc
10-06-2020, 06:55 PM | #161 | |
My heater box didn't use any, it took speed nuts instead. My LH front hanger had them, not sure if that's factory, doesn't seem right. Same as for the condenser on my other truck, strikes me as wrong, they were only on top.
10-06-2020, 11:14 PM | #162 |
I give up the double hex "double F" bolt (post 138). So close - that bolt mounts the rag joint assm. to the steering box shaft.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-06-2020 at 11:34 PM. |
