11-05-2020, 10:18 PM | #1 |
1971 K10 lsx motor mount help
Hey fellas I need some advice, I have a 1971 k10 half ton that is equipped with a sbc350 th400 transmission and NP205.. i plan to keep all the drivetrain the same except for the sbc350. I plan on putting in a 5.3 motor and I was looking for advice on which motor mounts/perches fit best. Thanks in advance fellas
F-Body Slut! Lol! |
11-06-2020, 01:05 AM | #2 |
All about them K’s
Re: 1971 K10 lsx motor mount help
I will move this to ls swaps, you’re likely to get more responses there.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-06-2020, 08:44 AM | #3 |
What you'll need is a set of adapters that locate the rear of the LS in the same spot as the sbc..
I used Ebay adapters on mine....worked perfectly... Mine look like pic down below but I see alot of people using the slider style..like dirty dingo
11-06-2020, 04:31 PM | #4 |
Cool, and then you just used your oem mounts and oem pedestals? Is your truck a k10?
F-Body Slut! Lol! |
11-06-2020, 10:00 PM | #5 |
mines a C30..but its the same...plates bolt to LS engine, sbc side bolts to plate...stock engine mounts...dropped right in, you could put the long bolts in with 2 fingers..
the slider style will give you a little room for error, so you might want to look into those.. heres a slider mount
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-06-2020 at 10:06 PM. |
11-07-2020, 12:44 AM | #6 |
All about them K’s
You need an ls swap crossmember for the 67-72 4x4 trucks.
This is just one of several options http://pacificfabrication.com/63-72-...ssmembers.html
11-07-2020, 03:04 PM | #7 |
Didnt know you had to change the crossmember ..what issues do the stock one create?..oil pan clearance?
11-08-2020, 11:08 AM | #8 |
All about them K’s
Yes sir, the pan doesn’t clear. I’ve read some people have had luck actually using the $50ish 55-59 v8 swap crossmember. I think I’m going to try that when I do my 6.0. It’s a hell of a lot cheaper.
11-10-2020, 10:48 PM | #9 |
Thanks alot for all the replies and help fellas. 57taskforce im really curious about the 55-59 chevy truck crossmember.. is there anyone else on here that can shed some light on this crossmember used on 67-72 k10?
F-Body Slut! Lol! |
11-11-2020, 12:12 PM | #10 |
I used the engine crossmember but I got mine from Jegs-someone here posted a link before. It worked for me. The only thing I noticed is that my engine seems to sit a little higher then the other crossmember kits. I have clearance every where but it is close to the fire wall but does not hit.
11-11-2020, 12:47 PM | #11 |
All about them K’s
http://67-72chevytrucks.com/vboard/s...=661982&page=4
Toward the end of this thread is where you find the 55-59 crossmember
