08-04-2014, 10:59 PM | #1 |
6L80 Tune (2-> 1 downshift questions)
New to the tuning world and I have been reading what I can, but I would like to address this one issue now if possible.
I am having an issue with the 2nd to 1st downshift- I basically need to bring the truck to a stop or nearly so before it shifts down. It's terrible if you are rolling into a red light and it turns green. The transmission will either stay in second and lug, or lurch into first usually at or below 2 mph. I have not changed a thing from the tuner I had do the original work. From looking at other 6l80 tunes, most 2->1 shifts (in Normal) are 7-9 mph @ 0% throttle, where mine is at 20 mph and doesn't occur until 1-2 mph. Am I reading that correctly? Should I look elsewhere for downshift properties? Any pointers would be appreciated. Well, I can't attach the file as it is too large (sheesh!) http://www.filedropper.com/1972blazer
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 |
08-05-2014, 06:34 AM | #2 |
Re: 6L80 Tune (2-> 1 downshift questions)
Lower the settings to 7 mph and it will be fine.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
08-05-2014, 08:06 AM | #3 |
I will give it a try, thanks.
I would like to know the 'why' behind the 'do' part if you or anyone could briefly explain- I like to learn this stuff for future use!
08-05-2014, 01:29 PM | #4 | |
meowMEOWmeowMEOW
Thats how I understand it from the reading. 6l80e's confuse the crap out of my because the Truck,car,and 'vette's were all setup and programmed a little differently.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-06-2014, 09:48 AM | #5 | |
It makes me wonder what else is wrong in the tune...
08-07-2014, 07:52 PM | #6 | |
email me a copy of your tune and I will take a look at it, r. R Edit: just noticed you posted the tune above.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-07-2014 at 08:03 PM. |
08-07-2014, 08:24 PM | #7 |
Steven,
I downloaded your tune and then downloaded a factory 2008 GMC Sierra 6.2/6L80 tune and then did a compare between the two. It looks like the guy that did your tune has some stuff jacked up in the auto shift sections of the tranny tune.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-07-2014, 09:24 PM | #8 |
Steven,
Make these changes to your tune and let me know what you think. R/
08-08-2014, 05:26 PM | #9 |
Sweet, thanks! I just got back in town, and I will load it and try it out. I will let you know!
08-08-2014, 10:52 PM | #10 |
Just went for a short test drive and it is a night and day difference, thanks!
No more 1st gear 5000 rpm shifts at 3/4 throttle!! It seems to go around corners in the correct gear now, too. I would like to stay in first just a hair longer, and second seems to drop off fast. Should i change the 1->2 and 2->3 shifts to a higher number on the throttle % chart? Thanks again for your help.
