10-29-2016, 06:05 PM | #1 |
What is this electrical component?
Guys,
I'm tracking down a voltage leak that has been killing my battery. This component has .5A going through the large red wire and out the small on with the key off, it still does it with the door closed (dome light off) So what does that littoe guy do? Where does the little wire go so I know what to check next. -Cody |
10-29-2016, 06:23 PM | #2 |
Re: What is this electrical component?
I believe that is your horn relay.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
10-29-2016, 06:24 PM | #3 |
Not sure of the location from context, but that's most likely your horn relay. But if it were stuck on, I'd expect the horn to be going.
Unless your horn is disconnected for that very reason... does the horn work?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-29-2016, 06:25 PM | #4 |
That is the horn relay. Red wire is battery green goes to the horn and small wire goes to the horn contacts in steering column.
10-30-2016, 03:00 PM | #5 |
The horn button on my Grant steering wheel has been ser funky for awhile now, I plugged my horn back in and it still didn't go off so I ruled that out, I found the button to be stuck thus killing my battery, that is for the help guys.
