Old 09-07-2014, 10:21 PM   #1
hotrod66
hotrod66's Avatar
63-66 gmc v6 motor mount stool to frame?
any one have a pic of a v6 motor mount stool thats out of a truck? i am thinking they may be the same as the one for a 292 I6 on the passenger side.
thanks David
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 09-07-2014, 10:55 PM   #2
padresag
Re: 63-66 gmc v6 motor mount stool to frame?
here is a set of v6 perches and a std v8 one. I do have a std r/side 292 perch around somewhere. if I run across it I will compare. the mounting holes are different for one instance at the centre insulator mount and the height of the perch at that spot seems to be different
ron
padresag is offline   Reply With Quote
Old 09-07-2014, 11:01 PM   #3
padresag
the first pic in the following link will perhaps show you the difference
http://www.persh.org/pickup/perches.htm
ron
Old 09-08-2014, 05:23 PM   #4
hotrod66
hotrod66's Avatar
ron
thanks ron. i have one 292 mount and it looks different than the v6 was just trying to think out side the box. i figured they would use the 292 mount on something ells but guess not. have had a tough time trying to find another mount for my other 292 truck currently it only has 1 thanks again guys
David
Old 09-09-2014, 12:32 AM   #5
Captainfab
60-66 Nut
I assume you are looking for the passenger side? If so I will look and see if I may have one.
David
Old 09-09-2014, 06:30 PM   #6
hotrod66
hotrod66's Avatar
that would be awesome!
Old 05-15-2017, 11:38 AM   #7
Budman56
Budman56's Avatar
So this is what I did because I couldn't find a perch. I cut 1 inch out of the top mounting holes, of a V-8 perch. then I used some roughly 1" nuts to space the top off the frame rail.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 05-15-2017, 12:21 PM   #8
padresag
did you ask for one. I usually have one around
ron
Old 05-15-2017, 03:28 PM   #9
Budman56
Budman56's Avatar
Thumbs up Re: 63-66 gmc v6 motor mount stool to frame?
ron
yep but no one had one so I made my own.
MY 65 C20 BUILD
Old 05-28-2017, 11:14 AM   #10
poledust
ron
Hi, I have a 1967 chevy c10 that I'm building with a 292 and I am in need of the passenger side engine perch? I was wondering if you might still have one? If so what would you let it go for? Thanks!
poledust is offline   Reply With Quote
Old 05-28-2017, 11:47 AM   #11
padresag
67 may be different I don't know. there are rules for buying and selling on here
ron
