Old 11-29-2020, 02:23 AM   #1
chev-obsession
chev-obsession's Avatar
Serpentine pulley conversion question
Hey guys, I bought a serpentine belt system to convert my 327. While I was pulling everything off the donor 4.3.... I started thinking....
Do I need to grab the harmonic balancer from the 4.3? Or do I use the balancer on my 327?
Is there a difference between the V8 and V6 balancer pulley’s? And if there is then should I be using the V8 pulley instead of the V6 pulley?
Any help is appreciated
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-29-2020, 08:02 AM   #2
b454rat
Re: Serpentine pulley conversion question
Try the 327 one first, not even sure what if any difference between a V6 and V8 balancer.
Old 11-29-2020, 11:26 AM   #3
Rickysnickers
You probably already know this, but in case you don't, you'll need to get a reverse rotation water pump.
Old 11-29-2020, 01:55 PM   #4
chev-obsession
Yep I knew that.
I’m only concerned about the balancer pulleys being different from the V6 to V8. And if I need the balancer from one or the other to put on the 327.
1965 c/10 swb
1969 c/10 lwb
Old 11-29-2020, 03:43 PM   #5
Rickysnickers
Ok, I wasn't trying to imply anything. Just doing a quick search on Summit's site, it appears as though they are both the same, meaning you can use the balancer you have. Here, take a look;
https://www.summitracing.com/parts/a...et?prefilter=1
Old 11-29-2020, 04:55 PM   #6
kwmech
Use the balancer that belongs with the engine
Old 11-29-2020, 10:57 PM   #7
chev-obsession
Thanks, I will go with that. I never thought to check summit
1965 c/10 swb
1969 c/10 lwb
