11-27-2020, 04:07 PM | #1 |
Intake manifold Brake booster plug
I will be installing a hydratech hydroboost brake set up in my Blazer. Because of this I need to plug the hole where the brake booster got its vacuum. Trucks with factory hydroboost have the plug in that location. I do not want to put a bolt in a hose!
Does anyone have the GM part number for that plug? It will look like this but it is solid instead of hollow.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-27-2020, 05:03 PM | #2 |
Re: Intake manifold Brake booster plug
Years ago I tried to find the part number for that plug and never did find one for it. The part its self doesn't have a number cast into it either. But if you send me your address I'll send you this one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-27-2020, 06:35 PM | #3 |
Information sent. Thank you so much!
11-27-2020, 07:42 PM | #4 |
Can’t you find and use a vacuum cap on the original fitting?
11-27-2020, 09:47 PM | #5 |
You could but why when they make the correct part?
12-01-2020, 06:02 PM | #6 |
AC Delco #12559760. This is the part number for the nipple.
Edit: I see that you are looking for the part number for the plug. Looks like ICT billet make a billet plug that you could use. I have a couple around somewhere, but I cleaned and not I can't find anything lol |
12-02-2020, 10:11 PM | #7 |
I have a bag full of those plugs.
Saskatoon, Saskatchewan Canada |
12-02-2020, 11:02 PM | #8 |
Do you have a part number ?
I have been looking as well I can find lots of vacuum booster nipples no vacuum plug numbers |
12-03-2020, 06:59 AM | #9 |
You wouldn't happen to have a part number for that bag full of them?
12-03-2020, 10:44 PM | #10 |
Did you not get the one I sent you?
12-04-2020, 04:06 AM | #11 |
No sir. But the part number may help others?
12-04-2020, 09:26 AM | #12 |
I sent it out Monday morning. I'll have to find the receipt from the PO to see what happened to it.
12-06-2020, 11:38 AM | #13 |
The luck I am having finding this plug is not working!
I had a vacuum cap on that port but the engine hiccupped and it took a long time to find the problem......... it blew the cap off, so I need a bag of the RIGHT plugs as I have 3 engines not using this port Thanks
