Old 11-23-2020, 05:28 PM   #1
Asshat
Asshat's Avatar
Is there a plastic replacement for the steel oil pressure line to the gauge?
Looking for a plastic hose to replace the steel line going to the pressure gauge.
Has anyone ever done this?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 11-23-2020, 06:19 PM   #2
dream66
Re: Is there a plastic replacement for the steel oil pressure line to the gauge?
The consensus on most car/truck forums shows a preference for a copper line vs plastic.
But, yes I've seen plastic ones from various part vendors.
dream66 is offline   Reply With Quote
Old 11-23-2020, 08:44 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I saw them on eBay and I think on Summit.
Old 11-23-2020, 09:16 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Steel bends better and doesn't break from fatigue like copper, which work hardens and cracks. Nylon is fine, but everywhere it makes contact, it should have something on it in case of chafing.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-23-2020, 09:43 PM   #5
chevykevy
chevykevy's Avatar
I bought a kit from a member who was putting together a kit with fittings and all a few years back
chevykevy is offline   Reply With Quote
Old 11-23-2020, 09:45 PM   #6
chevykevy
chevykevy's Avatar
Locdoc makes em, search oil line and locdoc
Old 11-23-2020, 09:51 PM   #7
rpmerf
rpmerf's Avatar
Theres a handful on Summit Racing. I'm sure Jegs, Autometer, and and similar have them also. Some braided stainless too.
https://www.summitracing.com/search/...ng&keyword=oil
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 11-24-2020, 04:54 PM   #8
forestb
forestb's Avatar
I think I have seen the plastic ones at Pep Boys.
forestb is offline   Reply With Quote
Old 11-25-2020, 11:23 AM   #9
LT1 Burb
LT1 Burb's Avatar
I had a plastic line once, until it blew off and dumped hot oil in the car, never again.
LT1 Burb is offline   Reply With Quote
Old 11-25-2020, 11:45 AM   #10
VictoriaHardware
VictoriaHardware's Avatar
I had a plastic line touch a header while on the running dyno. Pumped flaming oil all over the dyno room till the fire extinguisher calmed things down.
VictoriaHardware is offline   Reply With Quote
Old 11-25-2020, 12:27 PM   #11
forestb
forestb's Avatar
x2
But I have had both the plastic and the copper leak inside the cab. I use the electric type now. Not as accurate but accurate enough for driving around town.
Old 11-25-2020, 12:33 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
My plastic one got brittle over the years and then cracked and blew oil all over my engine. Better than in the cab I guess.
66 C20 Service Truck:
Old 11-26-2020, 04:32 PM   #13
Corts60
Just here to tinker
Corts60's Avatar
Please don't use plastic. All the reasons above are true. They are not trustworthy. Go with copper.
Old 11-26-2020, 09:41 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'd stay with steel, or use NiCopp. Regular copper work hardens and will eventually crack.
~Steven
Simi Valley, CA
Old 11-28-2020, 03:36 PM   #15
Asshat
Asshat's Avatar
Ok. I think I’ll stick with steel.
Thanks!
292, 4-speed
Old 11-28-2020, 05:32 PM   #16
Thealien
Thealien's Avatar
On my 1972 I purchased an AN-4 braided SS line and used brass fittings to attach. Flexible and less prone to crack than plastic, steel, or copper.
Just another option.
There are some pictures in this thread.
http://www.67-72chevytrucks.com/vboa...&highlight=Oil
Old 12-03-2020, 04:35 PM   #17
straight6chevyguy
straight6chevyguy's Avatar
Yes stay away from the plastic lines.
They do work for short term use but after some years they will become brittle and crack and break in a million places and pieces.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 12-03-2020, 04:36 PM   #18
straight6chevyguy
I have used copper lines and they seem to work fine for me.
To many projects!
Old 12-03-2020, 04:42 PM   #19
The Rocknrod
Moderator
I had my oil pressure gauge updated to the next series gauge and matching sender. No tubes for me.
