12-01-2020, 10:59 PM | #1 |
60-66 Nut
'60-'62 Bellhousing Mounts
Not having owned a running and driving '60-'62, I'm not sure what is correct here. Does the bellhousing bolt directly onto the metal arch part of the bellhousing mounts? Nothing in between?
12-01-2020, 11:32 PM | #2 |
Re: '60-'62 Bellhousing Mounts
From my '61:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-02-2020, 10:31 PM | #3 |
60-66 Nut
Those are the mounts I am used to seeing on the '63-'72 trucks and am well aware of how they go together. I guess since this frame I have is a '60-'62 GMC, these must be specific to the GMC's.
12-04-2020, 01:59 AM | #4 |
My 62 3/4 gmc 2wd mounts are identical to yours in your photo Capt fab
12-04-2020, 10:18 PM | #5 |
60-66 Nut
I kind of thought it must be a GMC thing. Is your bellhousing bolted directly to the metal part of the mount?
12-04-2020, 11:27 PM | #6 |
I will try and look at it tomorrow for you. My dads 62 chevy c20 with the 235 had the mounts typically found on 63 and later. Photos from the gmc shop manual x6223 show 1/2 and 3/4 like those in your photo
12-05-2020, 10:43 PM | #7 |
60-66 Nut
Thanks for the pics raylube. So it looks like I thought it should be, the bellhousing directly on the metal part of the mount.
12-05-2020, 11:34 PM | #8 |
03-21-2021, 01:18 AM | #9 |
BLAZER THIRTY!!
You can use later mounts in place of the first design I have on all my GMCs
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
03-21-2021, 01:42 PM | #10 |
I want say my 62 k20 chevy is like the first picture steel reinforced rubber isolator with a through bolt from the bottom its buried under 3 feet of snow and with a still busted leg I won't go near it tell it thaws
03-22-2021, 01:57 AM | #11 |
mine mounts just mounts to the rubber mounts on the crossmember
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
