Old 01-12-2012, 08:18 PM   #1
Laguna_kid
Laguna_kid's Avatar
67-72 frame specs...cab mounts
i was wondering if someone had the specs for cab mounts on the frame as well as motor mounts. i have seen dimension sheets on this form but have not seen the specs for the cab mounts
1970 c10
5.3l ls motor
ls1 intake, TB, injectors and comp
aluminum fuel rails
custom ground cam
Laguna_kid is offline   Reply With Quote
Old 01-12-2012, 08:36 PM   #2
dyrt
Re: 67-72 frame specs...cab mounts
are you referring to the locations of the cab mount holes with respect to both the length and width of the frame? I had to repair my brackets since they were so rusted out and was seeking the same information. I ended up measuring another frame and figured out everything as close as i could. What are you trying to do with these numbers?
dyrt is offline   Reply With Quote
Old 01-12-2012, 08:48 PM   #3
Laguna_kid
Laguna_kid's Avatar
yeah that's what i'm lookin for. well i'm building my own frame from the ground up and i dont have a frame to measure from. my old ones all cut up and almost sure its not straight.
1970 c10
5.3l ls motor
aluminum fuel rails
custom ground cam
Old 01-12-2012, 08:49 PM   #4
70cst
70cst's Avatar
Not sure if this helps but thought I would post it...
http://67-72chevytrucks.com/vboard/s...d.php?t=194004
http://67-72chevytrucks.com/vboard/s...d.php?t=406751
http://67-72chevytrucks.com/vboard/s...d.php?t=321874
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-12-2012, 08:58 PM   #5
Laguna_kid
Laguna_kid's Avatar
thanks 70cst but i need the frame specs and dimensions i have seen a few on this form but non show the cab mounts and motor mount specs on them.
1970 c10
5.3l ls motor
aluminum fuel rails
custom ground cam
Old 01-12-2012, 11:28 PM   #6
MAK191
is this what you are looking for?
MAK191 is offline   Reply With Quote
Old 01-12-2012, 11:41 PM   #7
YBNORML
YBNORML's Avatar
Great info. I actually needed this Thanks!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-13-2012, 05:30 AM   #8
Laguna_kid
Laguna_kid's Avatar
well i need most of this and this is the image i have seen before but it doesn't show measurements for the cab mounts just their location....
1970 c10
5.3l ls motor
aluminum fuel rails
custom ground cam
Old 01-14-2012, 07:02 AM   #9
Laguna_kid
Laguna_kid's Avatar
bump.....
1970 c10
5.3l ls motor
aluminum fuel rails
custom ground cam
Old 11-22-2017, 08:01 AM   #10
Desy180
Thank you for information! That's what I was looking for.
Desy180 is offline   Reply With Quote
