Old 11-20-2017, 06:32 PM   #1
Jenks1978
1978 K10 rebuild
So my dad bought this truck new off the lot. Its been in 2 different wrecks and been painted 3 times over the years. Originally it was a 1978 K10 Scottsdale and was dark brown. My dad handed it down to me almost 10 years back and I finally got tired of seeing it start to rust away. I slowly started making changes to it until I just said screw it and blew the thing apart to give it some of the attention it deserved. Before I started this last process, I had already changed out the axles for a 14 bolt and a another dana 44 with flat top knuckles and 8 lug to match the rear. I also swapped out the TH350 and 203 for a NV4500 5 speed and 205 tcase. Pictures of where it was before tear down. I was extremely rusted, even though the pictures don't show it.
Jenks1978 is offline   Reply With Quote
Old 11-20-2017, 06:36 PM   #2
Jenks1978
Re: 1978 K10 rebuild
I bought a 6.0 out of a 2009 Silverado and an 86 c10 to steal the cab off of and ditched the original cab that was shot.
Old 11-22-2017, 07:07 AM   #3
LT7A
Those stainless strips must've covered a lot of rust? It looked really nice and will be cool to see what you do with it. Maybe start a thread in the "builds" section?
In pic 2, what wheels and tires have you got there? And what size?
Old 11-22-2017, 12:16 PM   #4
Jenks1978
Sorry I just noticed there was a build section after I posted this. I can start a new posting there, unless an admin and just move it???
The wheels in the 2nd pic are 17x9 procomps. They are like the cheapest ones they sell or close to it. They didn't last long on it as I didn't like the looks.
Old 11-22-2017, 12:27 PM   #5
Jenks1978
I stripped the frame and did the POR 15 and painted everything.
Old 11-22-2017, 12:33 PM   #6
Jenks1978
Motor trans and tcase getting test fitted and the new cab back from sand blasting and with a coat of primer on it. Absolutely no rust on the new cab!! I also picked up a new cowl hood.
Old 11-22-2017, 12:41 PM   #7
Jenks1978
I also bought new fenders and did some modifying to open up the wheel wells some more to run bigger tires on a smaller lift. Took some material off the front and pie cut the back to push back the opening.
Old 11-22-2017, 12:47 PM   #8
Jenks1978
Just getting some of the chassis back together and got the new wheels and tires that I'll be running.
Old 11-22-2017, 12:51 PM   #9
Jenks1978
Getting the base color down on the cab
Old 11-22-2017, 12:54 PM   #10
Jenks1978
and the clear.
Old 11-22-2017, 12:55 PM   #11
Jenks1978
Cab is all done.
Old 11-22-2017, 01:01 PM   #12
Jenks1978
work on the bed.
Old 11-22-2017, 01:02 PM   #13
Jenks1978
more progress
Old 11-22-2017, 01:04 PM   #14
Jenks1978
more.....
Old 11-22-2017, 02:00 PM   #15
Mattchu60
Looks fantastic - did you paint everything in the garage? It looks very clean for just have been painted it - did you hang plastic or how did you keep the paint dust down?
Mattchu60 is offline   Reply With Quote
Old 11-22-2017, 03:15 PM   #16
Jenks1978
I painted the whole truck in my little two car garage. I did every part separate. I should have put plastic down but didn't. I still have a lot of paint dust in places. I just opened my garage door a couple feet and then ran 3-4 fans in the back of the garage to push the air out. I wet the floor down every time as well. This was my first time ever painting a car so it wasn't ever going to be perfect and its not a show truck or anything. I had little orange peel which I've sanded and buffed out pretty easily. That was the part that made me the most nervous was sanding a new paint job and fear of starting over.
Old 11-22-2017, 03:24 PM   #17
Jenks1978
I forgot to mention I also raptor lined the bottom of the bed, cab and inside the cab where I didn't paint. I also swapped out the column as the old original had seen better days. I also got the motor harness all hooked up and routed through the firewall where I'll hide the PCM under the dash.
Old 11-22-2017, 03:26 PM   #18
Jenks1978
And here is how it sits in the garage as of today.
Old 11-22-2017, 09:27 PM   #19
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Amazing looking! Keep up the good work!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-23-2017, 04:44 AM   #20
Feel the 'Pane
Pretty awesome job! Can't wait to see the finished product!
What color blue are you using, & how many coats of clear?
FtP
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver
77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10
Flatbed
82' Chevrolet K30 C/C: 454ci/SM465/205/D60/narrow 14B DRW/4:56
Flatbed, 6"Rancho, Alcoa's
Feel the 'Pane is offline   Reply With Quote
Old 11-26-2017, 12:38 AM   #21
Flames97
Flames97's Avatar
That's lookin good! I'm following!
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 11-26-2017, 07:14 PM   #22
Wwes
Looks good man, nice work. I'd like to repaint my own truck, and I'd have to do it in a similar size garage.
Wwes is offline   Reply With Quote
Old 12-01-2017, 11:40 AM   #23
Jenks1978
FtP
Its actually a paint code off a 2014 dodge that the guy at the paint store helped me with. It's got about 4 coats of clear on top of the 3 coats of base.
Old 12-01-2017, 11:44 AM   #24
Jenks1978
I got the gauge cluster all finished up and test fitted it all. Modified some of the stock parts alone with the LMC brushed aluminum piece. I don't have a finished picture but I sanded and buffed the brushed part more to give it a better finish and to have it match the factory stuff better. I wasn't real happy with the quality of the part when it first showed up.
Old 12-21-2017, 11:50 AM   #25
Jenks1978
amp back board and speak mounts built.
