07-05-2022, 01:56 PM | #1 |
S10 frame swap 1950 GMC lowering block size?
Just about done my swap 1950 GMC LS/4l60E and now my rear looks too low to me. I used the frame mounts from skymangs post, and have drop spindles in the front. My current rear lowering block is 3" thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
07-05-2022, 06:02 PM | #2 |
Re: S10 frame swap 1950 GMC lowering block size?
I'd stick a jack under the back bumper or frame and raise the back up to where I thought it looked right and measure the difference at the center of the wheel well and go from there. That probably isn't more than one/two inches.
07-06-2022, 10:38 AM | #3 |
I used 2 inch drop spindles and 2 inch lowering blocks, with 15 inch wheels, if that helps?
it's kind of trial and error as it depends on your cab mounts
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
07-06-2022, 06:42 PM | #4 |
do you have the wheels you plan to run mounted yet? I always set up a staggered set with different offsets and heights front to back, so a 3/3 drop always works out to a 3/2 or 3/2.5 and a roughly level ride height. that said, if you feel the rear is too low, and you have been driving a little and the front springs have fully settled, just go to a smaller block. (while I am thinking of it, make sure your front springs are seated! holds more guys up, literally, than they like to admit)
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-07-2022, 12:14 AM | #5 |
Thanks Gents..
I think the rear springs of the S10 frame have sagged..The previous owner used it as a scrap hauler and always had a load on it. I am going to cut my 3" rear block in half and see how it looks.
07-07-2022, 11:24 AM | #6 |
I wish I removed and replaced my rear leafs when I had the truck apart. The ride is a little stiff and I think that would help smooth it out. (they are probably seized)
Now that the truck is all together, I really don't feel like doing it. Looks great, keep at it
