08-14-2019, 09:35 AM | #26 |
Almost Satisfied
Re: 12 bolt rear diff cover
Went to order it and it shows out of stock...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
08-14-2019, 11:19 AM | #27 |
Go figure. the part number is: A9070PBK, and when googling that, I found the below one.
Diff Cover It shows as out of stock as well. You might email or call them to determine when these might be back in stock.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 08-14-2019 at 12:25 PM. |
08-14-2019, 12:31 PM | #28 |
Almost Satisfied
Thank you for that. Looks like they are the same place. I called and he said 4 to 6 weeks. I will keep an eye on it. I don't have to have one right away.
08-14-2019, 12:41 PM | #29 |
I will keep my eye peeled for a good straight one since your not far from me. I frequent the Springfield craigslist page.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
08-18-2019, 12:44 AM | #30 |
Picked this one up several years ago off ebay.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
08-24-2019, 10:47 AM | #31 |
Z10, that looks good! I saw it on eBay as well for roughly $70.
08-24-2019, 10:49 AM | #32 |
I mounted my cover on and it fits as it should with no issues. I still need to sandblast and paint it, but I’m happy with the results.
08-24-2019, 10:55 AM | #33 |
On another note I purchased ARP cover bolts and to my surprise they are too long. At this point I can grind the excess off and true the bolts up with my bench top grinder or stack washers which would be far less time consuming. Not sure if others have ran into this and ARP may make a shorter 12 bolt cover bolt. Sorry in advance for the sideways pictures.
08-24-2019, 02:53 PM | #34 |
Moderator
The bolts that come with the aftermarket covers are too long as well. I just re-used my originals.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-24-2019, 03:23 PM | #35 |
I purchased washers to use to decrease the length of the bolts, but am unsure if I will use them. I might just reuse my stock bolts.
08-24-2019, 10:39 PM | #36 |
I did some more digging and the stock rear diff cover bolts are 5/16-18, .50” in length under head, serrated. The ARP bolts for a 12 bolt rear cover are 5/16-18 and .750” long under head, part # 437-3002. A more ideal ARP bolt to use would be the 612-0560 bolt, it is 5/16-18, .560 under head length and after using the washer the bolt is right at .50” in length under the head of the bolt while using the washer.
I know this is nerd bolt info but maybe it will help somebody down the road that is using the stock steel cover. The ARP .750” length bolts might work well with an aluminum cover if it’s a thicker casting. ARP Bolts
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 08-25-2019 at 10:53 AM. |
08-25-2019, 10:43 AM | #37 |
Nice, great info. Thanks for sharing!
72 C10 lwb fleetside -stock 350/350 combo |
06-04-2020, 06:45 PM | #38 | |
https://www.assaultracing.com/item/4...-truck-12-bolt
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 06-04-2020 at 07:01 PM. |
06-04-2020, 10:35 PM | #39 | |
06-05-2020, 08:07 AM | #40 | |
Canton stainless stud kit on Amazon less than $20. Same with Mr. Gasketbolt kit. And you get 20 of them instead of 10. Two sets will let you do 3 diffs with 4 extra bolts.
06-05-2020, 11:11 AM | #41 | |
An alternative would be nice. Is this the Mr. Gasket Bolt Kit you are referring to? https://www.amazon.com/Mr-Gasket-608...1369688&sr=8-7
Photo Gallery of 1972 K/5 Blazer CST |
06-05-2020, 09:04 PM | #42 |
Yes, that 6086 kit is the big chevy/pontiac kit.
Here is the Moroso version: https://www.amazon.com/Moroso-38560-...1405271&sr=8-1 The Canton stud kit: https://www.amazon.com/Canton-Racing...1405285&sr=8-1 Milodon bolt kit: https://www.amazon.com/Milodon-85005...405430&sr=8-17
06-30-2020, 01:38 AM | #43 |
Replaced the chrome differential covers front and back with black OE style covers. It looks cleaner in my opinion. Thanks for your help tracking these down for only $35.
06-30-2020, 09:52 AM | #44 |
Sweet Blazer! I agree that the black cover does look cleaner as well.
11-29-2021, 07:42 AM | #45 |
Moderator
Another bolt with a hex head in stainless (less cost)
https://www.boltdepot.com/Product-De...?product=17455 Or even less cost (zinc plated) Grade 5 https://www.ebay.com/itm/25210350877...8AAOSwvx5bYvjN
