Old 06-08-2019, 09:18 PM   #1
flyboyjack
flyboyjack's Avatar
And now I can see!
I posted a thread a couple days ago bemoaning the fact that the side mirrors bought from Brothers and other stores will not work on the passenger side. It was then I found this was a common comment and yet Brothers, et al continue selling these as fitting 71-72 C10's. I initially thought about cutting the shaft between the two swivel balls and welding a short extension. Then when looking into the mirror from the bottom I could see that it was threaded. I applied a LOT of pressure with needle nose vise grips and backed the mirror off from the mount. It took a LOT of grunting ,... I'm pretty sure they used Lok Tight on the threads. Once off, we reinstalled the threaded portion back into the base only 2 1/2 turns and then put a SS nut between the base and the swivel on the mirror. I also had to Dremel a part of the retaining flange on the swivel/ball to gain enough movement for the mirror to function as it should. (Someone else did that previously somewhere out there. But w/o extending the mirror armature, I don't think it worked well). This works. I can see the side of the truck from my position in the driver's seat. Once you have the mirror apart, there are several other ways to "skin this cat". I just took the easiest. (I think).
flyboyjack is offline   Reply With Quote
Old 06-09-2019, 12:24 AM   #2
cornerstone
cornerstone's Avatar
Re: And now I can see!
Good thinkin! When it comes time to install my new mirrors, I'll do it this way. Makes sense that the added length on the shaft gives the head of the mirror more rotation. Thanks
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-09-2019, 03:07 AM   #3
Southpaw69
Good job getting that handled. Definitely something I'm going to try with mine. if there's red loktite on there a heat gun might make for less grunting. Thanks for posting this solution.
Southpaw69 is offline   Reply With Quote
Old 06-13-2019, 10:39 AM   #4
rcazwillis
How about some pics of what you did?
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 06-13-2019, 10:47 AM   #5
68 P.O.S.
Yes, pics would be much appreciated
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 06-13-2019, 12:17 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
X3 on the pics
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-13-2019, 03:05 PM   #7
flyboyjack
flyboyjack's Avatar
OK,....here are two pics. One is the driver's side. No need for any adjustments. The other shows how I added a spacer nut, (temporarily), to extend the length of the mirror adjustment arm. I will replace the current nut with either SS or with a piece of thick walled SS or aluminum tube.
Remember, these mirrors are threaded and TIGHT! (At least mine was). After removing the mirror by unthreading it, we reinstalled it and only did about 2 1/2 threads in. This adjustment works for the truck seat to be fully aft. If you sit closer, this once again may not give you what you need. (There is a way to extend this even further, but you'd have to thread the inside of the hollow mirror thread to accept a bolt, then weld,...…).
I hope this helps.
Old 06-20-2019, 08:15 PM   #8
rcazwillis
Excellent. I can see this with a piece of polished stainless threaded on one end and tapped on the other to extend the bolt verses the nut.
Great idea. We will do this to Zane's 71. If it works, I will post some pics.
Zane's 71 Build
Old 06-21-2019, 11:44 AM   #9
flyboyjack
flyboyjack's Avatar
Adding the SS is what I was/am planning on doing. This was just a frustrated stop-gap fix that I did. The armature can even be lengthened more by threading the inside of the mirror threads. (It's hollow). Just install a bolt tack weld and extension, cover with SS,...….
But it's just great that there finally appears to be a relatively simple fix to what all our friends at LMC, Brothers, etc., keep selling us as OER equipment and taking advantage of us and our fondness for our trucks.
Old 06-21-2019, 01:24 PM   #10
elorenzof
Excellent out of the box thinking. That's why i love this forum and check it regularly its the best one out there for our trucks.
elorenzof is offline   Reply With Quote
Old 06-21-2019, 02:58 PM   #11
MySons68C20
MySons68C20's Avatar
Most helpful! I haven't installed my pass side "sport" mirror yet because of this issue.
Thank you!
Blake
MySons68C20 is offline   Reply With Quote
Old 06-21-2019, 04:39 PM   #12
54blackhornet
54blackhornet's Avatar
Why not just turn your head a bit ? That back window allows a panoramic view...
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-21-2019, 05:01 PM   #13
flyboyjack
flyboyjack's Avatar
That’s easy for you but try that with a cracked vertebrae.
Thread Tools
Display Modes
