04-22-2007, 10:49 PM | #1 |
Mounting Methods for Blazer Tank Swap
I picked up a Blazer tank swap kit a few weeks ago for my Beater. It came w/2 mounting straps but they don't resemble anything like the straps used in the FAQ's installation thread. These had the bends no where near where they should be based on the pics I've seen on other installs.
Anyway.... I was thinking about raising the tank so it sat between the frame rails. Do you guys think the tank would be ok if it was only supported by the flanges instead of the straps pulling the flanges up to the bottom of the frame rails? I've made 2x2 stainless spacers that are the length of the tank flange 're-inforcement' piece (reinforcement flange = 12", spacer length = 14"). I was going to put the j-bolts through the original tank-flange & reinforcement-flange holes , then through the SS spacers, & finally through some fresh holes in the top of the frame rails. I would then tighten the j-bolts until the tank is secure from the top of the frame vs. the bottom. This will raise the tank about 2-2.25" & should make my hidden receiver the lowest part of the rear end. Any thoughts or concerns?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-22-2007 at 10:52 PM. |
04-23-2007, 01:19 PM | #2 |
Re: Mounting Methods for Blazer Tank Swap
TTT.... Anyone?
04-23-2007, 01:33 PM | #3 |
My blazer tank's sending unit was less than an inch away (maybe closer?) to the bottom of the bedwood. I think trying to raise the tank (especially 2+ inches) isn't going to work.
Also, hanging it by the flange probably isn't a good idea. The flange on these tanks isn't very strong and wasn't meant to support the weight of a tank loaded with fuel. Chances are it would crack after a short period of time (especically a tank made with todays cheap, thin materials.)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-23-2007 at 01:34 PM. |
04-23-2007, 01:41 PM | #4 | |
I'll prob have to weld-in a lip on the outside of the frame rails for the j-bolts/straps to use.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-23-2007 at 01:45 PM. |
05-01-2007, 09:17 PM | #5 |
Wooooooo Weeeeee. . . ...... Something went right for me! I've been trying to figure out a way to raise the tank & support it properly & think I have the solution.
I cut down & modified the thin (flimsy) strap that came w/the kit so that they would support the tank just like if it was mounted below the frame. Once I got an idea on the length & bends needed, I looked all around my work (dairy manufacturing plant) for some stainless that I could somehow use. I found some 'pipe hangers' that we use on 6" plus diameter piping (they're 3/16" thick stainless x 2" wide w/a 45° & 90° bend). I dug through the stainless contractors 'recycle' bin & found 2 old hangers that had been cut off of outdated equipment. I'll cut each one in half & use each of the halves @ the 4 corners of the tank. I'll pick-up some flat 3/16" x 2" strap & get them to weld it up so I have a hanger that's the width of the tank. I'll run bolts from the bottom through the rail, up through the tank flange & the stainless spacer, then through the top rail where I'll use a nylon crush nut to keep everything from vibrating loose. In the mock-up..... the tank is flush w/the bottom of my ECE hidden receiver so you won't even be able to see it behind the bumper.
05-01-2007, 09:50 PM | #6 |
Happy to be here
I see working all those late hours has it perks...
