Old 09-25-2005, 08:34 PM   #1
jec
jec's Avatar
NP205 Transfer Case Shift Pattern
I just finished installing my shifter after disassembly, cleaning, and lubing with lithium grease. Much to my suprise, I now have a total of five (5) positions, instead of, the previous four (4) positions. I thought everything was working properly before as I had 4Lo, Neutral, 2Hi, and 4Hi, however, I must have been mistaken.
Is this a factory shifter for a 1972 K20 truck?
The pattern I now have is as follows from front to rear:
4 Lo
2 Lo
Neutral
2 Hi
4 Hi
Anyone else have the above shift pattern?
jec is offline   Reply With Quote
Old 09-25-2005, 08:36 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Never seen one w/ 5, mine has all of the above except 2wd high
*Actually I didn't look at it, I'm just going by memory, so I could b wrong
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-25-2005, 08:43 PM   #3
wolfthing2000
I believe that the transfercase is just not engaged all of the way into low range. Some Jeep transfercases do this and it can realy cause you trouble if you get on it with only partial engagement!!! Y ou are doubling the torque to your rear drive line and axle, with a healthy v-8 you stand a good chance to break something. I had a 76 truck with auto tranny and it had the 203 transfercase and it would do exactly as you describe. Just engage farther and everything willm be functioning as it should.
wolfthing2000 is offline   Reply With Quote
Old 09-25-2005, 09:09 PM   #4
al's71gmc
4 eyed fever
al's71gmc's Avatar
I've never seen one with the 2wd low, but there are times I wished I had one with a hi geared truck, no granny 4 spd. Sounds like you're only engaging it part way. Does your shift knob show 2L? I'd be worried about a sudden 4wd engagement when your under torque..that might do some damage.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 09-25-2005, 09:23 PM   #5
wolfthing2000
What he said!
Old 09-25-2005, 09:42 PM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
You can 2 low out of a NP 205, but that's with a twin stick conversion...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-25-2005, 09:48 PM   #7
70short/step
70short/step's Avatar
The 4 Gm 4X4's I have had various years. The N/P 203 had
2Lo
4Lo
N
2Hi
4Hi
The N/P205 had
4LO
N
2Hi
4Hi
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 09-25-2005, 10:05 PM   #8
Scrubby
Check out GMTrucks.org
Yeah, no case stock has a 2Lo. I bet your in between gears with the front output disengaged, but the range in low. Probably not good on your case to run like that.
You can get 2Lo with a twin stick setup on a 205. Kinda cool because you can also select which axle you want driving in 2wd.
Scrubby is offline   Reply With Quote
Old 09-25-2005, 10:07 PM   #9
72 CustomCamper
huh ???
2Lo
4Lo
N
2Hi
4Hi
The N/P205 had
4LO
N
2Hi
4Hi
Only way a NP 203 can have 2 low and 2 hi is with a part time conversion. The NP 203 is a full time 4x4 case. The shift pattern for a NP 203 is
4 lo lock
4 lo
N
4 hi
4 high lock...
Chuck
Old 09-25-2005, 10:08 PM   #10
Scrubby
2Lo
4Lo
N
2Hi
4Hi
The 203 shift pattern is:
Low Loc
Low
Neutral
High
High Loc
It is always in 4wd because it is a full time case. If you have it converted to part time it becomes:
4 Low
2 Low
Neutral
2 High
4 High
More info here: http://www.gmtrucks.org/wiki/faq/transfer_case
Old 09-25-2005, 11:14 PM   #11
jec
jec's Avatar
More specific details on my transfer case shift pattern.....There are two (2) levers on the transfer case itself. The outer lever has three (3) positions and controls ratios with rear pos. = Lo, center pos. = Neutral, and forward pos. = Hi. The inner lever has only two (2) positions and when move forward engages the front driveshaft (4WD).
All five (5) positions are distinct and positive. I am sure there is not any partial engagement of gears, etc. The operation of the shifter is as follows:
Full forward = outer lever back (Lo), inner lever forward (4WD).
Position 2 = outer lever back (Lo), inner lever back (2WD).
Position 3 = outer lever center (neut), inner lever back (2WD).
Position 4 = outer lever forward (Hi), inner lever back (2WD).
Full Back = outer lever forward (Hi), inner lever forward (4WD).
The operation of the transfer case levers is function of the shift lever. I may try to get some pics. tomorrow since my cab is removed and everything is easy to see. Hopefully, someone can identify what type of shifter I have.
Old 09-25-2005, 11:45 PM   #12
72 CustomCamper
huh ???
Sounds like a twin stick conversion for a NP 205...
Chuck
Old 09-26-2005, 01:01 PM   #13
jec
jec's Avatar
Found a picture of my exact transfer case and shifter on Evil Bay. It is mated to a TH400, however, everything from transmission back is identical to my set-up.
Maybe this is an NP203. Ad says it is out of a 1977 Chevy Blazer.
Old 09-26-2005, 06:07 PM   #14
72 CustomCamper
huh ???
That case in the pic is a NP 203...
Chuck
Old 09-26-2005, 06:12 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Chuck
Old 09-26-2005, 07:54 PM   #16
jec
jec's Avatar
Thanks for all the feedback.
The popular opinion says that I have an NP203 converted to part-time.
I included some pics of my set-up.
Old 09-26-2005, 11:13 PM   #17
72 CustomCamper
huh ???
That is 100% a NP 203...
Chuck
Old 10-05-2005, 08:30 PM   #18
Rod
I'll second that..its a 203.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
